kenne bell 2.6 vs. whipple
Old Jun 7, 2007 | 11:08 AM
leech's Avatar
Originally Posted by JimIII@jdm
Spray is another game because everyone runs a different shot and system
off the spray the numbers to beat in a FULL Weight Streetable truck
Don Justus 10.16 Whipple/ JDM Alum
Jeff Bruso 10.19 Whipple/ JDM Alum
Gator 10.22 Whipple/ JDM Alum
Leonard Watson 10.23 Whipple/ JDM Alum
Fuzz and V Man 10.32 and 10.33 Whipple/ JDM Iron
Dont anyone say Gary soulage 10.10 because that thing as light as a feather. Literally.
JimIII
I hope to get my JDM aluminum motor soon, maybe another low 10 sec. L running around
Old Jun 7, 2007 | 12:21 PM
Hilander's Avatar
So it's the DMP KB truck that is knocking on a 9 sec pass with spray versus Ricks truck? I thought Ricks truck ran pretty heavy with bed lid etc and has a best of 10.8 or so?
Are these the trucks that are going to race?
JimIII
Wow Jim these are some kick **** times for huffer only runs
Old Jun 7, 2007 | 06:58 PM
scuba-matt's Avatar
Subscribing
Old Jun 7, 2007 | 07:07 PM
Rob_00Lightning's Avatar
JimIII
Ya but WE did it only using 100HP for 4 seconds of the run, I say let them spray it as much as they want, I aint no scaddy cat
Sup Jim
Old Jun 7, 2007 | 07:36 PM
cowman's Avatar
Its (cowman) and this time were just running boost and we put the lid back on and the seat back in . We are both running 8 pound lower and 2.7 upper. but there wont be any fast ETs. lacr is a slow track they dont much to the track. But it should be fun.
Old Jun 7, 2007 | 10:33 PM
Black 2000's Avatar
JimIII
Do you mean full weight as in 4444lbs with driver? Thats what Don Justus's truck weighed in at the last MM&FF Lightning shootout when it went 10.14 on the spray. You telling me you guys added 500lbs to it recently?
Later...
Bruce
Old Jun 8, 2007 | 12:40 AM
superlightningc's Avatar
cool deal
Thats awesome guys Im interested to see how they do! Looks like we will be making a trip to Cali this year for FFW because of Saleen. Ill try to convince Don Justus to come out and see if we cant see what he does in your conditions!
JimIII
That sounds GREAT!!!!!! I Hope he comes with you all. I think this would be some GREAT heads up Racing.
Old Jun 8, 2007 | 11:09 AM
St Louis Lightning's Avatar
Later...
Bruce
Old Jun 8, 2007 | 11:52 AM
lightninquick's Avatar
yep,,,my little ol can of bolts has only managed a 10.8,,,,but to give you an idea what kinda conditons Lacr has,,,,,only two trucks have EVER ran faster then 11.1 with boost only there ask the mighty dale01 what his best ever boost only run is,,,lol,,,sorry dale
comparing timeslips wont work in this situation,,,taking down a 10.0 truck with a 10.8 truck will
Old Jun 8, 2007 | 11:55 AM
JimIII@jdm's Avatar
Former Sponsor
Later...
Bruce
What Dons truck weighed there was more than most of the trucks i hear of running good times weigh. It also went 10.16 @ JDM day no nitrous, and a 9.96 with a 75 shot. And that article was done in August, so yea it was maybe a little warm out.
Dons truck has already race in the 10.30 ET range in competition this year with over 200lbs in the bed too! And has made about 60 1/4mile passes 10.7 or better since March, who else has done that!!!
4950 isnt a Lightning thats a frieghtliner. I consider full weight between 4400 and 4700lbs because thats what most weigh. And if your racing a truck that weighs that much its alot of extra stress on the motor.
JimIII
Old Jun 8, 2007 | 12:32 PM
LightningTuner's Avatar
Originally Posted by superlightningc
dyno are for numbers only.the track tells it all.the track we are racing @ is 2700 ft elevation with no DA factor and is one slippery snake. THe whipple has the better lane also.
If you are comparing two blowers against each other, then your "shootout" is a waste of time.
If you want a REAL comparison, run ONE truck, then swap the other blower onto that truck, the same day, and run again. Of course you'll have to make sure they both are using the same pulley configuration, and make sure the timing and A/F are the same for each setup.
That's the only way to do a valid test of this nature, on a track. Any other comparison's results should be taken with a grain of salt.
Old Jun 8, 2007 | 01:03 PM
whip's Avatar
JimIII
Werd! I consider my truck full weight. The only thing removed is the spare. With race rubber on basic aluminum wheels, a 1/4 tank of gas, and my 170lb *** in it, she usually weighs 4700lbs, with a best of 4660. NOTHING REMOVED but the spare.
And I agree that there are too many variables in this test, but if you make 5-10 passes in each rig, its a good start.
Old Jun 8, 2007 | 03:49 PM
Hilander's Avatar
Exactly, thats what I was aiming at when I asked what trucks were racing.
I thought that they both ran at LACR and had times of 10.8 versus 10.3 or so on boost. Correct me with the real numbers Rick. If that is the case you can easily guess what truck "should" run faster.
Should be great fun anyway fellas, best of luck to you both, especially the Whipple truck haha.
Old Jun 8, 2007 | 04:03 PM
nobody has ever ran faster then 10.8 boost only at lacr,,,,,ever
Old Jun 9, 2007 | 01:42 AM
race cancelled
the race has been canceled due to an L brother in need of some help
http://www.socalloc.com/forums/showthread.php?t=2772
