HELP!! which heater core hose is inlet?
Old Jan 5, 2001 | 11:12 AM
Lightningquick's Avatar
Post HELP!! which heater core hose is inlet?
I am in the process of installing the temp sending unit for my autometer gauges.Ther are two hoses that go into the heater core.
right/left
d.side/p.side
looking at the truck from the front,which is the inlet? d.side or ps side??
Thanks guys.
i do not want to take out the plug in the block,id rather get the temp on the top of the motor like the factory,the block would be a little hotterand more accurate but I dont feel comfortable doing this.
Is this where you guys have installed the sending unit(heater core hoses)???
To me it looks like the easyest without interupting anything major.
Oh yea,looks as though I will be losing a coil again.The famous #4 coil was dirty and I touched the bottom of the hose above to find out it is wet.They did not even fix this after putting in a new coil??!! what idiots.This is called fixing the symptom not the probleM!!
Old Jan 5, 2001 | 02:17 PM
Post
Its done,It works the *****.Then i had to disasemble it until my pillar comes in.I used the d. side hose and it works flawlessly.
NOTE.... when doing this using heater hoses with a TEE,Make sure you ground the sender or you will get very little reading.It took me a while to figure it out but,These senders are made to be self grounded into the block.It can be done in line of hose,you just need to add a wire to the bolt.
Old Jan 5, 2001 | 08:45 PM
Neal's Avatar
Cool
HI!... LIGHTNINGQUICK : Yes, the heater hose closest to the driver's side is the proper one to tap. I installed a mechanical AUTOMETER temp guage about a year ago and that's how I did it. Hope this helps you out, or at least assures you that you tapped the right hose.
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Old Jan 5, 2001 | 09:10 PM
Post
Thanks neal,
Heres a good one.I called my dealer to find out what size the hole was so i could buy a tee.They had no clue,they only listed a stock number.I think its a 5/8 hose now because i used a 1/2 tee that fit perfect.
3/4 hose= 5/8 tee
5/8 hose= 1/2 tee
I also asked about what was the wire that sent the signal from the 02 sensor to the ecm,they again had no clue.I got a call back and they told me the red/yellow wire.Im glad i did not go with their advice,i would be buying another gauge!! I used summit which contcted autometer which i confirmed on their site.
Makes you wonder what they know,
Old Jan 6, 2001 | 06:09 PM
Post
top for who asked
