HELP!!!! Water Temp gauge install?????
Old Jan 6, 2001 | 04:48 PM
afj00svt's Avatar
Question HELP!!!! Water Temp gauge install?????
I just recieved my Phantom Boost and Water Temp gauges.....Has anyone installed the mechanical Phantom Water Temp gauge(140-280deg) on their L's? I couldn't find a place to install the sensor?
Red 2000 SVT Lightning
[This message has been edited by afj00svt (edited 01-06-2001).]
Old Jan 6, 2001 | 06:08 PM
Lightningquick's Avatar
Post
I just made a big post about this 2 days ago.I will put it to the top for you .remember to ground the sensor using a electrical loop connector 3/8" loop
Old Jan 6, 2001 | 06:15 PM
afj00svt's Avatar
Question
Thanks L-Quick for the help...forgive me, but I'm not as knowledgeable as everyone on this board.... is the driver side hose to the heater core marked, where do i look for it? Did you use a brass T?
Old Jan 6, 2001 | 06:27 PM
Post
I got a 1/2 inch plastic tee with a 5/8 female comection from my local hardware store.It was like this tee was made just for my lightning !! in the pluming dept,Not automotive.
I sliced the heater core hose slid everything on and clamped it and tried my gauge.Make sure you ground the sending unit if you dont your gauge womt work.This is done by using a wsher and a 3/8 electrical loop hole connector and this goes inbetween the sensor and the brass nut you use to actually screw into the tee.When you get your gauges,you will get 2 different brass connector,Use the big one with the washer and loop hole between.Hope this helps.You are gonna need to crank down on these sending unit and brass fitting in order to ground and stop it from leaking.DO NOT crank down the fitting into the plastic tee,You will break it Youll see what I am talking about soon as you dig in.
Bye the way,The heater core hose is the one that is starting you right in the face
Old Jan 6, 2001 | 06:45 PM
afj00svt's Avatar
Question
