Power Pipe for our Lightnings
Old Jan 3, 2001 | 10:27 PM
HIGH ROLLER's Avatar
Talking Power Pipe for our Lightnings
I spoke with a gentleman today from Anderson Motorsports that is making a power pipe for our L.He said that it would replace the rubber boot and would connect between the mass-air and the throttle body he is going to dyno this pipe to see what the gains will be and if it works out for gains it would be available by spring!
Does anybody know or have experience with the power pipe installed on a vehicle!I know they use them on cobras,what kind of gains are they getting with it!
HIGH ROLLER
Old Jan 3, 2001 | 10:46 PM
Twinturbo Ranger's Avatar
Thumbs up
Well it's really not that big of deal to make one,but on my old blown 93 it did make a difference. I made my own by using 4 inch pipe. I'd be real curious on what it does for these trucks. I used it on a Vortech. Keep me posted on what they find out and I'll fab me something up myself!!
00 White Lightning,R9 Superchip,Homemade induction with cone type K&N filter,Magnaflow Muffler. 93 Ford Ranger,FI 302 with 185 AFR heads,GT-40 lower intake w/Downs upper,65 mm TB,66 lb injectors controlled by Western Motorsports SDS fuel injection,TDC Stage 2 twin turbos,AOD trans w/Lentch strip valvebody,10 inch convertor and single input shaft,8.8 rearend w/mosier 31 spline axles and 3.73 gears,and plenty more !!
Old Jan 3, 2001 | 10:49 PM
dogleg's Avatar
Post
I want one!
99.5 Ford Lightning - Full Bassani exhaust, Swanson Performance Chip,Pro-m,undersized pulley,3.73 ears,Transgo shift kit,Cal-trac bars, cobra type hood, snug top cover,2" drop in back, yellow stripes down red truck.
13.01 @ 103.6, 378 RWHP
http://www.zing.com/album/?id=4294235379
Old Jan 4, 2001 | 10:26 AM
SVT-Snake's Avatar
Post
Wouldn't aluminum transfer more under hood heat to the incoming air than rubber does since metal transfers heat better. Or is this negligible since the intercooler would be after the power tube? Just wondering.
00 Black Lightning
No mods yet
00 Honda Civic
01 Pontiac Grand AM GT
Old Jan 4, 2001 | 05:53 PM
wrightlightning's Avatar
Question
What exactly is a "power pipe"?
Black '00, Pro-M, Swanson Flip Chip, AIM 2" drop kit, JL Ram Air on order
Old Jan 4, 2001 | 06:00 PM
gforce's Avatar
Post
I hate that rubber boot and was wondering about it just last night. It seems to me that its bumpiness and bent curvature would cause major turbulence to the incoming air charge.
SVT-Snake, I see your point, but there is so much metal downstream of the boot, I don't think it matters.
Black '00
#1,757 built 3/30/00
Clear corners
J.L. Single program
J.L. Stage II ram-air
Old Jan 4, 2001 | 06:16 PM
JIGAWATT's Avatar
Talking
NFE Jason,
I'm sure John told you he sold the Vette? It's now at a local car lot up here. Yes, it did make a big change in how the Vette ran.
Glad to see you got your Lightning
Kevin
Old Jan 5, 2001 | 12:13 AM
NvrFastEnuf's Avatar
Post
I recently sold my 94 Supercharged Corvette. A couple months before I sold it I replaced the pancaked Vortech intake pipe with a 3.5" tubular pipe and I gained nearly 60 hp. Obviously that wouldn't be the case on the L because the stock pipe isn't squished like the Vortech's was, but I'm sure it'll make a difference. It was an awesome addition to the vette and gained me so much power I had to reprogram my fuel curve. The car ran high 12's @ 113 w/o the pipe and did a best of 12.2 (street tires) @ 122 with it!
Jason
<font face="Verdana, Arial" size="2">Originally posted by HIGH ROLLER:
HIGH ROLLER
</font>
Red 99, JL Flip Chip, Airaid, Kameleon Head Unit, Thunderforms.
[This message has been edited by NvrFastEnuf (edited 01-04-2001).]
