Which Spark plugs are the best?
Old Jan 3, 2001 | 05:54 PM
Lightningquick's Avatar
Post Which Spark plugs are the best?
I have seen alot on here about spark plugs and missing electrodes and such.i am trying to find the best spark plugs to use.ALL opinions are what i am looking for.Please post why you think they are the best and I know they are hard but what is the process?
Old Jan 3, 2001 | 09:53 PM
noelvm's Avatar
Post
718 post and you haven't learned how to use the search engine? Wow!!! The missing electrodes mostly had to do wieh N20 and alloy (platium) plugs. Before one could answer your question one would have to know what your application requirements were? Basicly the stock plugs are fine without juice. Some swear by the multi electrode plugs but since electricity follows the path of least resistance, it will always fire over the shortest least resistant path which is the same reason multi electrode plugs were snake oil in the 50's and are snake oil today. Guys have had good luck with the Jap plugs and the wider gap seems better that the close gap. (do a search to find gap, look for 1badtk post.)
noelvm
noelvm
99.5 Red Ligntning, Mobil 1, PRO-M 80 MM MAF/filter, Custom Superchip, Eldebrock 5512 muffler, MT ET Streets, best time (1/8) 8.19, Bugflector II, G&H Lens covers head & fog, 200 WT Pioneer 4 CH AMP, BOSE 301 SERIES IV SPEAKERS (IN BACK)
70 Vette LS-6 454 (gathering dust in the garage)
Old Jan 3, 2001 | 10:52 PM
Twinturbo Ranger's Avatar
Thumbs up
noelvm you are the first person besides me and my Grandfather to say that about the multi-electrode plugs. Electricity will always go to the closest one first. As far a the answer for plugs on these trucks I don't know,but I would like to know if anyone has used a cooler heat range? Thanks Mike
00 White Lightning,R9 Superchip,Homemade induction with cone type K&N filter,Magnaflow Muffler. 93 Ford Ranger,FI 302 with 185 AFR heads,GT-40 lower intake w/Downs upper,65 mm TB,66 lb injectors controlled by Western Motorsports SDS fuel injection,TDC Stage 2 twin turbos,AOD trans w/Lentch strip valvebody,10 inch convertor and single input shaft,8.8 rearend w/mosier 31 spline axles and 3.73 gears,and plenty more !!
Old Jan 3, 2001 | 11:11 PM
LTNBOLT's Avatar
Cool
You can't go wrong with the NGK TR-6 or Splitfires. The Splitfires have an increase in throttle response.
No plug is going to offer a big performance gain if that's what you looking for.
Later,
Chuck
Black 00
Chuck's Lightning Page
Old Jan 4, 2001 | 12:30 AM
THEAUTOMAN's Avatar
Post
NGK br7efs (stock #1094) is a far superior plug for a blown engine than the tr6 or similiar plug. My book shows the tr6 as a direct replacement for the stock plug (same heat range) The br7efs does not have the projected tip therefore moving the business end farther away from the chamber which is good in our application. Got to ngk.com and you can type in plug numbers and it will show you what they look like. Check the tr6 and then the br7efs and you will see what I mean. Just my .02
2000 Silver L #4906
Best 1/8th mi stock:9.13
Best with R9 and 5,000 mi: 8.67
1995 Stang : (wifes'car) 12.30 1/4 mi
1972 Skylark: 7.16 1/8, 6.70 on the bottle
Old Jan 4, 2001 | 12:36 AM
THEAUTOMAN's Avatar
Post
Sorry, it's NGKSPARKPLUGS.COM
