First Oil change
Old Dec 30, 2000 | 06:24 PM
Hilander's Avatar
Post First Oil change
My L is comming up for 1000 miles so I feel it is about time for it,s first oil change.
I purchased Valvoline 5W-30 oil along with a Bosch filter.
I have read not to use fully synthetic until about 3000 miles. What is the opinion here?
Also the book says to change oil at 3000, I feel that is too long for the first change. In case of any loose stuff from the engine build. Again what milage did you guys first change the oil?
Thanks to all that voice an opinion.
2000 Lightning Silver frost
Clear corners (Front only)
PSP Intake, Bed Rug, Snuglid
Old Dec 30, 2000 | 06:41 PM
gforce's Avatar
Post
Hilander,
Change it to get the break-in metal particles out. Obviously, the oil is not worn out, but full of microscopic metal particles. I've rebuilt many engines and pay attention to this stuff and even the best filters don't seem to get it all out. I changed mine at 1,200 miles and I'm glad I did.
As far as synthetics go, I have read and heard the same things as you. But, there are many manufacturers putting synthetics in the factory fill. Corvette for one. But you should do what you feel comfortable with. SVT said not to do synthetics until 5k miles. I dunno. Worked fine for me.
Black '00
#1,757 built 3/30/00
Clear corners
J.L. Single program
J.L. Stage II ram-air
[This message has been edited by gforce (edited 12-31-2000).]
Old Dec 30, 2000 | 07:22 PM
LightStruck's Avatar
Post
I'll bet you can get more opinions on this as any other topic, but:
I changed filter (Motorcraft) @ 1000. Added Ford 5W30 to top off.
Changed oil & filter @ 2500--Valvoline DuraBlend 5W30 & Motorcraft filter.
Change oil & filter at every 2500 using Valvoline DuraBlend& Motorcraft.
I like to change often--so I don't buy full Syn. or Premium filters.
Just another opinion.......
Old Dec 31, 2000 | 03:00 PM
TomG's Avatar
Post
Hilander,
Be careful about the filter you use. The recommended Motorcraft filter is the FL-820S. This filter has a flap in it to prevent backflow. Not all filters do. I believe the "S" designates this flap. I put synthetic oil in at 3,000 miles. Your plan sounds good to me.
Tom
Old Dec 31, 2000 | 03:31 PM
JohnnyLightning's Avatar
Wink
I changed mine @ 3,000 i used mobil 1 syn.5-30.i change every 4,000 everything seems to be fine i now have 17,000 miles on it. pretty hard miles too! most of it was a 1/4 mile at a time i also have a filter magnet to help JL
93 cobra 10.90@127.00
99 lightning (black)
e.t. 12.41 @ 110.8
best mph 110.8
60 ft. 1.79
JL superchip
JL ram air
JL Powercooler
2# pulley
Level 10 shift kit
SuperChip Dist.!
(Man i love this truck!)
_ _ _________________ _ _
JohnnyLightning Performance
E-mail: jlightningracing@cs.com
WEB:webtechnik.com/johnnylightning
Old Dec 31, 2000 | 05:56 PM
Hamrhead's Avatar
Post
Every 2500 from the get go,with conventional oil.
Mike Hague
'99 BLK LIGHTNING 13.13@102.26
'95 COBRA R #58 13.18@106+
'91 GMC Syclone 12.05@111.5,,so far
Old Dec 31, 2000 | 09:37 PM
bggroth's Avatar
Post
I also changed mine at 1000 miles, and put in mobil 1, no problems. My 00 Cobra R came with Mobil 1 in it from the factory also (15w-50).
Brian
99 red lightning, bassani complete system #1610 of 4000
2001 arctic cat zr440 snopro on the way
2000 super duty v10
Arctic cat 400 4x4
Cobra "R" #131 of 300
Moderator
www.svtperformance.com
Old Jan 1, 2001 | 09:06 AM
GalaxyEng's Avatar
Post
The "S" in the FL-820S designates a Silicon anti-drain back valve. My daily driver 95 Contour SE has the same filter, it does a great job of keeping the oil in the top end for cold starts.
GalaxyEng
2000 RED #2926
BedRug, Haig custom mats
