Chip problem r9
Old Dec 28, 2000 | 05:35 AM
FASTBOLTofLIGHT's Avatar
Unhappy Chip problem r9
I had just recieved my R9 chip for the 99 but on position1 there is no problem but as i put it on position 2 the truck just stops asoon as i put it in gear i have checked the connection and there is no problem i have taken it of then cleaned the connector again then put the chip back and it still did the same thing stopped could you guys help me
99.5 Lightning
Downs intake
Superchip
Slotted Rotors F&R
Lo Pro Tonneau
Netro wing
Alpine Command unit
Old Dec 28, 2000 | 10:01 AM
RTKILLA's Avatar
Post
Did you remove all the glue from the computer and wipe in off with alcohol. You might have a bad connection, and if thats not it then you have a bad chip. Call up your dealer and ask for a new one.
99.5 red lightning
COMPLETED MODS:
Cervini's ram air hood, billet grilles, clear coreners, clear tail's, A.R.E bed cover, SS street style mirror's, Super chip R9, airaid intake, trans go shift kit, lightning floor matts
Painted brakes, that was cheap.
PROJECTS IN PROGRESS:
Complete bassani exhaust
bell tech 3/4 drop kit
belltech shocks
wiper cowl
Sir Micheals roll pan Sir Micheals tail gate skin and handle relocator
COVER YOU EARS:
Kenwood 9015 cd, Kenwood kmd minidisc, Kicker 5x7 impulse, kicker 5.25 resolution, phoenix gold zx450, Phoenix gold zx500, Three JL audio 10w3's, Qform's, custom built box.
MAY BABIES STAT'S
Built 5/4/99, yes A tuesday!
# 917 of 4000
Best ET. 13.42 at 100.98
best stock 13.96 at ?
When the green light drops, the bullsh*t stops.
WORDS TO LIVE BY
Old Dec 28, 2000 | 02:39 PM
Former Sponsor
Post
Hi Fast,
Sorry to hear you're having a problem!
You don't say that it won't start in Position 2, you say that it stalls when you put it in gear. Since the engine starts up OK, it's probably not the connection between the Superchip and the computer, though this should *always* be double-checked. You might have a problem with the switch itself, so that should be checked, just take a look at the wiring to see if it's loose where it attaches to the switch.
Though it is very rare, it is possible that the second eeprom chip has failed, but usually when that happens the engine won't ever run at all in Position 2.
One thing you'll want to make sure of, is *never* try to change programs while the engine is running. Always make sure you shut the engine off before flipping the switch.
I'd say to check the wiring on the switch itself, to see if it's become detached or loose, it's pretty simple to check. If you continue to have this problem, then you should have the Superchip looked at by whoever supplied it to you. If that was us, just give us a call or shoot us an email.
Good luck!
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
Old Dec 28, 2000 | 10:58 PM
Post
Mike
Will the first thing is I had the connectors cleaned and had the chip taped to the CPU I will have to check the connection of the switch will get back you asoon as i find out
99.5 Lightning
Downs intake
Superchip
Slotted Rotors F&R
Lo Pro Tonneau
Netro wing
Alpine Command unit
