Before I get to involved. Can I do this.
Old May 2, 2007 | 09:01 PM
Jkstang78's Avatar
Can passanger head be removed while motor is still in the truck. Any tips on what I should look at out for to make it eaiser.
Old May 5, 2007 | 05:28 PM
Shorty's Avatar
i'm not certain but I believe you may have to remove the head studs in order to clear the fender. Hopefully someone else will confirm. Why do you want to remove the head? blow a plug? If so then you don't need to remove the head.
Old May 6, 2007 | 06:52 AM
Rob_00Lightning's Avatar
JK I guess this means the insert wasnt a possbility "or" you already tried it and it didnt work That sucks!!!
Either way the Heads can be taking out with the motor in place but it's a real PITA. You should talk to Sal he has a few tricks when doing it.
Best of Luck and man that sucks
PS
Could this be one of those "I hate to do it but" times where the most logical thing to do is (I cant believe I'm about to say this) yes let Ford do it
Ah the good ole days when you could take out a Big Block Chevy Motor rebuild it and be driving it the same day....
