Intercooler fluid?
Old May 7, 2007 | 07:32 PM
tlfwatch's Avatar
Smile There Is No Magic Trick In Water Wetter
The only thing that helps are bigger heat exchangers electric fans etc true the more cooler air you have going into motor help creates horsepower don't try to use lower degree thermostat that only adds to problem i do not use nothing but 50/50 mix and i am at 600 hp i am useing double by pass heat exchanger with fans. more on the use of lower degree thermostats and the harm it can cause later. tom
Old May 7, 2007 | 11:38 PM
khendrix2374's Avatar
I will most likely add a couple small fans in series with a switch with the IC pump. That way I can run the fans and the pump with truck turned off.
I want to lessen the possibility of detonation anytime I'm driving, not just at the track.
Thanks for all the replies.
