Those running slicks
Old Nov 23, 2000 | 02:05 AM
wrightlightning's Avatar
Question Those running slicks
For those of you using slicks at the drag strip, do you manually shift through the gears? Since the slicks essentially lower your rear gear ratio, how do you get your trucks to shift correctly? Maybe a "special" burn on a chip?
Black '00, Pro-M, Swanson Flip Chip, AIM 2" drop kit, JL Ram Air on order
Old Nov 23, 2000 | 10:43 AM
JIGAWATT's Avatar
Wink
Tell your chip maker that you are, or have changed your tires or gears. They will give you the correct shift points for what ever combo you have. ie: 4.10 with 26 inch slicks, or what ever you have.
You can not do a manual 1-2 upshift, under full throttle. The L will go into the rev limiter before it shifts.
Old Nov 23, 2000 | 11:01 AM
noelvm's Avatar
Talking
Tire size has nothing to do with transmission shift points. The counter on top of the rear end measures ring gear revs and reports that info to the computer. It is true that 26" slicks with a 3.55 give around a 3.70 actual rear ratio. This seems to be a better combo than the guys that are running 4.10 rears which have an actual ration (with 26" tires) of around 4.33. I say this because they seem to have much more trouble getting traction. I believe the best combo would be the 4.10s with 28" tires. Unfortunately, this combo is not easily or cheaply achieved.
noelvm
Old Nov 23, 2000 | 11:25 AM
sixpipes's Avatar
Cool
Noel is right. The transmission shifts on RPM, not speed. The 3.73s I am running along with the MT Street 26X11.5X16 tires give me the 4.10 (+ or - a few percent) ratio that I was looking for. Shift points (rpm wise) can be determined by the chip program.
With an aftermarket chip, my truck shifts much more efficiently (and safer too) than I could ever accomplish manually.
[This message has been edited by sixpipes (edited 11-23-2000).]
Old Nov 23, 2000 | 11:30 AM
Lightning Boy's Avatar
Post
Yeah, we have had our PSP chip re-programed for 3.73 28" (street) one one program and 3.73 26" (strip) on another program. And with the 4way chip you cna change progrma on the fly, and dont have to turn your truck off, or clear the PCM.
Thomas 'Lightning Boy' Shelton
SVTPerformance.com
BOARD MODERATOR:
-Dynos, Time slips, and best ETs
-Nitrous/Forced Induction
Old Nov 23, 2000 | 02:26 PM
Spiro99SVT's Avatar
Post
I just leave it in drive, and hold on for the ride.... of course, launching at 2k makes it feel even better
Spiro-"The Greek"
BLK. #1476
Best run to date
12.373 @110.15
Best 60` 1.76
@ 4800 lbs.
On Pump Fuel
_________________________
JDM Engineering- Ford Specialist
Johnny Lightning Performance
http://www.webtechnik.com/johnnylightning
"Empty Pockets Racing"Drag Race Team NJ-DE
Spiro99SVT@aol.com
LAUNCH HARD !!!
Old Nov 23, 2000 | 06:46 PM
Wink
Thanks for all the info, guys. I have been wanting to take my '00 to the strip, but I really wanted to get some slicks first. I have stock gears, and did not want to waste my time if the truck shifts incorrectly (too soon, too late, etc).
Old Dec 23, 2000 | 04:19 PM
eddie silver lightning's Avatar
Post
how do you like your lowering kit? I am looking to lower mine but i am hearing about problems in different areas with different kits(bottoming out,to soft,etc.)Please let me know.
Old Dec 23, 2000 | 05:39 PM
Cool
eddie,
I have only dropped the rear end 2". I LOVE the way it makes the truck look now. It has a "level" stance. Ride seems less springy than it did before. No bottoming out.
