Need Help part 2
Old Dec 19, 2000 | 02:44 PM
99SVTBoy's Avatar
Question Need Help part 2
If my coil is bad from the coolant leak from the hose will I hurt my L more by driving it till next week ? I dont want to be carless over x-mas weekend if i dont have to. Nedd your guys advice. Thanks in adance.
Old Dec 19, 2000 | 02:50 PM
Hawkeye's Avatar
Post
If the coil is bad, you will know because you will have an engine miss. Unless you drive a lot during the next week or two it should not hurt anything.
If the engine is not missing then the coil is still OK but you should have the dealer look at it and make a note of the leak so if the coil does fail later they will replace it under warranty.
