Whipple help
Old Mar 10, 2007 | 12:40 PM
Rob_00Lightning's Avatar
Originally Posted by Ricki F-150
Plug change is ok as no EGR.
BULLSCHITT
Old Mar 10, 2007 | 01:06 PM
JollyGiant's Avatar
Sorry but I must agree with Ricki.
With the snap-on tool for removing/installing the blower bolts, my last plug change took 48 minutes start to finish.
Once you get over the fact that the extra work of removing the blower makes the job easier, it is a piece of cake.
Old Mar 10, 2007 | 03:06 PM
PLEASE GIVE INFO ON THIS SNAP ON TOOL YOU SPEAK OFF
As you prob know I'm kind of an expert on changing plugs with an Eaton, Mag, or KB, but when I look at the Whipple under my hood now it outright scares the schitt out of me
Although I will never have to do a plug change on the fly like the old days,
I do want to be prepaired, THANKS
Old Mar 11, 2007 | 12:50 AM
JollyGiant's Avatar
Go back up to post #12 and you will find a link to info about the tool.
Old Mar 11, 2007 | 10:03 AM
Thanks Bro
It is a 10mm wrench - snap-on part FRDHM10 $27.50
I'll tell you one thing for a super co like snap on "their site sure does suck".
NOTHING on the site works, NOT ONE LINK ??? I guess I'll try it again another time, maybe their having problems ???
Old Mar 11, 2007 | 10:28 AM
leech's Avatar
Originally Posted by Rob_00Lightning
Thanks Bro
I tried to order the wrench from snapon, they are out of stock
Will check with my snapon guy on wed. to see if he has one on his truck...
Old Mar 11, 2007 | 03:25 PM
JollyGiant's Avatar
I just went to the snapon site and typed frdhm10 in the search box. It took me to the tool and I put one in my cart. The cart said it was in stock???
Old Mar 11, 2007 | 03:44 PM
leech's Avatar
Yea, I tried to order it under my industrial account and it said 0 in stock!
I just tried under the retail catalog and it said they were in stock
Old Mar 22, 2007 | 03:05 PM
ARE YOU FRIGGING KIDDING ME
This is what you get for $30.00
It's about the size of your Thumb Nail
OR SOMETHING ???
Old Mar 23, 2007 | 02:57 AM
promodlightning's Avatar
Dont forget to grind some of the box end off Rob.
Old Mar 23, 2007 | 06:06 AM
Talk to me promod ?
So is this "only" to re-torque and I need to grind it down a bit ?
( yikes how much smaller can u make it )
Maybe I'll do the plugs for schitts and giggles in the next few weeks to see what this is all about, I just wanted to make sure I had anything special I needed so I can change the plugs some day.
I guess $30.00 aint bad since u can use it as a cool little key chain too
Old Mar 23, 2007 | 11:18 AM
Tim Skelton's Avatar
This is what you get for $30.00 . . .
C'mon Rob. You at least have to give them some credit for supplying a post-assrape cigarette.
Old Mar 23, 2007 | 02:40 PM
JollyGiant's Avatar
I'm using mine as I received it. No grinding necessary here.
Old Mar 24, 2007 | 03:27 AM
I had to grind mine down and so did Leach. You must of clearenced your intake around the bolt holes bigger.
Old Mar 24, 2007 | 07:42 AM
JollyGiant's Avatar
No, but I do have one of the earliest Whipples. Maybe the manifold is slightly different.
