Need Factory Coil Spring Spacer
Old Mar 2, 2007 | 01:43 PM
svtsilverback's Avatar
i need a set of the factory rubber coil spring spacers. just ordered a set of hotchkis coils and you need to use the factory spacers. sold mine last year. i know you can run the springs w/o the spacer but i want to use a set. thanks brian
Old Mar 2, 2007 | 06:10 PM
todd abbott's Avatar
contact Energy Suspension.
Old Mar 2, 2007 | 06:47 PM
Tim Skelton's Avatar
That won't work. According to information recently posted in another thread, Hotchkis coils are no longer ground flat on the top. Silveback needs the stocker.
Old Mar 3, 2007 | 02:10 AM
yes i need some stockers. man i would hate to know what a dealership wants for them or if they can even get them.
Old Mar 3, 2007 | 11:05 AM
Sorry about the incorrect info, I just read a post a week or so ago about Energy's spacer's is 3/8 and I believe 1/2 inch, guess I should have read a bit more careful.
Old Mar 3, 2007 | 11:17 AM
If the part I'm seeing on fordpartsonline is correct, they are $11 list, $7 discount.
Old Mar 8, 2007 | 03:07 AM
thanks tim. i got my sway bars and coils today.
i was looking at the hotchkis coil springs and they might work w/o the spacer. they are not flat like the ruslow springs but are very close. you can stand the spring on its top and it will set there. may order a set of new spacers anyway though.
Old Mar 8, 2007 | 09:52 AM
If it does not look like one part of the coil will dig in, I would get some urethane isolators.
Old Mar 8, 2007 | 10:53 AM
pitstain's Avatar
Belltech has some nice shaped coil spring spacers with a notch in them for non flatted springs.
Old Mar 8, 2007 | 12:10 PM
thanks guys. i am going to install the spacers. hotchkis techs said using the springs w/o spacers would be okay. noise and lower ride height were the only downfalls.
