HELP Losing Boost
Old Oct 20, 2000 | 01:32 PM
ralleyone's Avatar
Post
What, if any mods do you have? How many miles? The R7 program of the Superchip gave my L some similar problems, although you've got a few extra things going on leading me to believe it's coils or the infamous intercooler leak.
Old Oct 20, 2000 | 01:49 PM
Mystic Lightning's Avatar
Unhappy
Bone stock, , 27,000 miles.
Had the cooling hose leak right from the start, fried 3 coil packs and two plugs,
dealer replaced w/new style cooling hoses,
TSB on that one for all F150's, replaced burnt coil packs, 8 new plugs. belt is definately glazed. pullies are shiney. They topped off my intercooler last oil change haven't seen a drop in fluid level yet...When they pulled the plugs 1st time 2 electrodes totally gone!!! had some octane boost in there, almost wouldn't do under warranty! ooops!
Thanks for the replies, will check the rear coil, get the part # for the new belt a few theads back.
Old Oct 20, 2000 | 02:22 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Post
Mystic,
Manufacturer: Gates
Part #: k080660
When I did my belt swap, my stock belt was beginning to glaze. Mileage was 14,000.
hope this helps,
Brake Late, Dive Deep
Speedin Bob
'99 'Red Rocket' Lightning #2504, 6/17/99
NLOC # 438
13.56 @ 100.89, 1.97 60' on F-1's
JL Ram Air, R9 Chip,Keyless Entry, Retrax Bed Cover, Shackles, Wet Okoles, Mobil 1/FilterMag, Corners & Tails
Autophysics filter FOR SALE [9" x 3.5" Red Trim]
Old Oct 20, 2000 | 02:36 PM
Cool
Thanks Speedn Bob. I'll replace this weekend.
Old Oct 21, 2000 | 12:36 AM
Question HELP Losing Boost
Any help here,
last few days, have had the blower belt slip if I mat the throttle let out of it completely, I hear this awful sqweeeel!
Now when I mat the throttle, @ highway speed, it drops down a gear which is normal, but the boost immediately maxes out 1 or 2 seconds max, then drops off to about 4lbs, and starts to build again. Cough... belt slip? New plugs? I've also noticed a cruise 70mph My L runs rough, misses ever so slightly, coils bad plugs??? Anyone with similar problems.
Thankx
Old Oct 21, 2000 | 12:54 AM
BlackLight's Avatar
Unhappy
Check your intercooler fluid level.
Old Oct 21, 2000 | 12:57 AM
4D THNDR's Avatar
Post
Check the rear passenger side coil pack. Sometimes the heater's hose drips on that one and shorts it out. Look for even a small amount of the green fluid on it. As far as belt slippage, hmmmm, is the old one glazed or loose? Maybe time for a new on, dunno.
Red '00 Lightning,
Power Surge Performance enhanced,
Sound effects provided by Flowmaster,
13.227@103.55
Old Nov 1, 2000 | 08:52 AM
Houndog's Avatar
Question
I have 2700+ miles on my truck and got into it a little..Only making 6 lbs. boost according to the oem guage..Any ideas ??
Thanks..
Old Nov 1, 2000 | 11:01 AM
LHound's Avatar
Post
I've got a similar problem. Sometimes when going WOT my L will cough and sputter as if it is losing boost. Seems to happen when I jump on it from highway cruising speed, I've never noticed it from a dead stop. I don't know if it matters but I've got the R9. I've only got about 3500 miles on mine.
Old Nov 1, 2000 | 11:15 AM
Houndog's Avatar
Post
Mine runs ok,, I also have the R9, but I see people making 10 lbs. boost And I'm only making 6 max...
What could be the cause ? I also have a drop in K&N...
