Shaker Hood for the L
Old Feb 13, 2007 | 04:04 AM
01SLVRBLT's Avatar
I just bought a shaker hood from a friend but I need the shaker part of it. Does anyone know where I might be able to locate one pretty cheap. I only paid $100 for the hood painted. I am not sure if the mach 1 hoods are the same. Any info would be great.
Old Feb 13, 2007 | 10:38 AM
Tim Skelton's Avatar
The only place to get one is from Keystone. I paid $200 just for the mounting hardware. Get out your checkbook.
Old Feb 13, 2007 | 01:22 PM
01SLVRBLT's Avatar
wow, thats really high. I already have $100 in the hood and dont have any mounting hardware or the scoop. Well, what I thought was a good deal just turned into " I could have just bout a new one".
Old Feb 13, 2007 | 03:24 PM
Hawkpilot's Avatar
The mach1 shaker system from Ford runs upward of $700 if you have to replace one. Having said that, you can often find used rigs on ebay or on the classifieds at http://www.mach1registry.com/
I will say that you will need to do some fabrication to make a mach1 rig work with the lightning, especially the brackets and stuff. Then there is the piping if you want to make it function.
From what I recall of the keystone system, the piping is going to be completely different, since I think it uses channels in the hood to route air to the special airbox that is made by them. If you just want the look, I am sure you could make a mach1 scoop fit with a little work though.
I can tell you that a mach1 hood ain't gonna fit a truck. I have one of each...
Old Feb 13, 2007 | 09:03 PM
jackal 2's Avatar
the shaker scoop of the mach1 it's smaller than the scoop that comes with the keystone shaker, my friend has a mach1 and we put his scoop on my L. just to see and it looks funny, it won't even cover the hole you can see inside the engine bay.
Old Feb 14, 2007 | 03:56 AM
01SLVRBLT's Avatar
Thats the exact hood I have thats in your sig. I think it came from Lightning Force Performance. Maybe I can call them and get the brackets and scoop.
Old Feb 14, 2007 | 11:24 AM
VINNIE's Avatar
your looking for this scoop to work with the hood.
Here is the brackets that hold the scoop in.
I run this scoop myself. LOL
Old Feb 14, 2007 | 03:00 PM
01SLVRBLT's Avatar
is that a keystone hood Vinnie?
Old Feb 14, 2007 | 10:35 PM
Yup, that's the Keystone.
You will need the $200 hardware kit and the top and bottom halves of the scoop. You may get out for less than the cost of the whole hood, but I wouldn't bank on it.
Old Feb 15, 2007 | 04:06 AM
01SLVRBLT's Avatar
I can make the brackets no problem at all. I just need the scoop halves. maybe they will reply to my email one day...
Old Feb 15, 2007 | 10:49 AM
Call and ask for Phil.
