Lubrication of Ball Joints?
Old Oct 21, 2000 | 08:26 PM
wilywilky's Avatar
Question Lubrication of Ball Joints?
Hello to all:
I was performing the 15,000 mile scheduled service today on the L when I noticed in the Scheduled Maintenance Guide, under Additional Services for Light Trucks, that Ford requires inspection and lubrication of 4x2 ball joints.
Having observed that there are no zerk grease fittings on the ball joints, I was wondering how do you go about lubricating these joints?
Hope this isn't a dumb question, but at least, now it has been asked.
Thanks in advance.
Wilk
'97 F-150 4x4 Super Cab; XLT 139" Wheelbase Flairside; Silver Frost Clearcoat; 4.6L. (Romeo); 4-spd Automatic Transmission; Preferred Equipment Package 507A; 3.55 Limited Slip Axle; Electronic Shift 4x4; California Emissions; Sliding Rear Window; Trailer Towing Package; Off-Road Package; 6-Way Power Driver's Seat; Remote Keyless Entry/Anti Theft; 6-Disc CD Changer; Ford Bedliner; Ford Running Boards; Ford Nose Mask; Roll n Lock Tonneau Cover.
2000 SVT F-150 LIGHTNING XLT; 120" Wheelbase; Flareside; 5.4L EFI SOHC V8 SC Engine; 4-SPD Automatic; Silver Clearcoat Metallic; SVT Online Store Lightning Front End Mask; Roll n Lock Tonneau Cover.
Old Oct 23, 2000 | 03:49 PM
Gary Franconia's Avatar
Cool
PBGas is right you can't really service them you just have to inspect them and make sure that the are ok and not damaged or wearing out! I recently lowered my L and took the upper a-arm apart from the spindle, on the drivers side I put a small cut in the ball joint boot, but it should be ok because the upper ball joint doesn't carry as much of a load as the lower one does, I'll just have to keep a close eye on it and make sure its ok from time to time
Old Oct 23, 2000 | 04:24 PM
noelvm's Avatar
Talking
Not serviceable. Designed to last 31,000 miles. When they get loose replace them with aftermarket with grease fittings. Us synthetic grease and the second set will probably last forever.
noelvm
99.5 Red Ligntning, Mobil 1, PRO-M 80 MM MAF/filter, Custom Superchip, Eldebrock 5512 muffler, MT ET Streets, best time (1/8) 8.44, Bugflector II, G&H Lens covers head & fog, 200 WT Pioneer 4 CH AMP, BOSE 301 SERIES IV SPEAKERS (IN BACK)
70 Vette LS-6 454 (gathering dust in the garage)
Old Oct 23, 2000 | 08:11 PM
wilywilky's Avatar
Smile
Thanks guys!
Once again the members of the F-150 Online Message Board have helped me to understand the workings of my truck a little bit more.
The help and information is greatly appreciated.
Thanks also to Webmaster Steve, for his efforts in sponsoring this forum, and for the free exchange of information and ideas that come with it.
Wilk
Old Oct 24, 2000 | 12:39 AM
wilywilky's Avatar
Post
b.t.t.t.
Anyone know the answer to this maintenance question?
Wilk
Old Oct 24, 2000 | 12:47 AM
PBGas's Avatar
Post
I gather that this is one of those areas that it could be model specific. If there are no grease fittings, then you can't really service them because they are permanently sealed units. I was wondering the same thing myself.
So....my initial answer would be, inspect and replace if damaged. I wonder if the ones that you would replace them with would have grease fittings......probably...
Paul G.
