I need Help
Old Jan 18, 2007 | 01:56 AM
2-tone-L's Avatar
Unhappy I need Help
Need Help
I just installed these upgrades and the truck feels slower then stock and it dosn't seem like the throttle response is there anymore and feels like it is running rough
K&n air filter
90mm mass
true flow elbow
accufab throttle body
ported plenum
stiegiemiers ported super charger
2.80 upper pulley
4lb lower
4:10 gear
up gradded girddle
brisk silver tips gaped at .40
oil separtor
grantiele coils
boost bypass
160 thermstat
heat exchanger
sct tuner
Old Jan 18, 2007 | 05:49 AM
chief40al's Avatar
Do you have a can tune or a tuners tune?
Did you set the TPS when you changed the throttle body?
Old Jan 18, 2007 | 06:32 AM
Rob_99Lightning's Avatar
If I had to guess (providing everything is hooked up right) I say the Maf....
1- You should notice a HUGE difference
2- If it's running rough something is wrong
3- .040 is awfully big for that boost level (could be a problem in itself)
As Al stated the first thing to discuss here is "who tuned it" and was it tuned for the Maf Change ? (Maf change ='s mandatory change to your tune)
Adding pullys even a Ported Eaton even coils and plugs and even a diff intake WOULD NOT make your truck run bad or slower (even without a tune change)
As for the roughness that clearly tells me right off the bat something is wrong. I would try a few things like checking each and every vac line you touched, each and every plug and connection you touched, and then even consider starting the truck and pulling a coil connection at a time to see if you can find a specific cylinder not firing. Maybe a coil or plug is bad, maybe a coil is unplugged, maybe an Injector is upplugged, maybe a vac line is unplugged or wrong, maybe the bypass was done wrong, there is much to check.....
Either way personally I think .040 is too big and you may experience spark blow out (which will cause the truck to run rough) been there done that and at less than a .040 gap
Good Luck and please let us know how you make out
(btw, try swapping back to the original maf a second and see what happens......)
Old Jan 18, 2007 | 09:39 AM
pitstain's Avatar
WOW did you instsall all that stuff at ONCE !?!?
It's gonna be really hard to track down the problem with all those changes.
regap the plugs to .035, or better yet get some NGK TR6, or denso IT22 plugs.
call your tuner who you purchased the SCT from, hopefully it wasnt from ebay.
check all your vaccum hoses for leaks.
put the old 80mm mass air on just to see what happens.
make sure you throttle posistion sensor reads near .99 volts with the throttle closed.
Old Jan 18, 2007 | 12:18 PM
2-tone-L's Avatar
This is my first L so i don't know that much about them the guys at LFP told me to gap them at .40-.45 and also how do you check to make sure the tps is installed correctly
Old Jan 18, 2007 | 01:08 PM
TrackBeast's Avatar
When you modify a vehicle you should do one thing at a time. that way if something isn't right, you can track it down. A ported blower will cause you to loose torque below 3500rpms (up to 40ft/lbs) but your pulleys should compensate and what you end up with in terms of torque is no better than stock.
No offence but it really seems that you don't know where you're going with your mods and you admit to not knowing what you're doing.
Before modding, it is better to research and understand. Throwing *sh*it* at the wall and hoping it will stick is not the right approach.
TB
Old Jan 18, 2007 | 01:16 PM
todd abbott's Avatar
The first thing I would do is put in a set of NKG TR-6's and put the OEM coil pacs back on as this is the cause of many issues, from there I'd get the truck on a dyno to see where our at fuel wise and speak to your tuner to see where your timing is, minus any vac leaks or BS install issues my guess is this will take care of your problems. Good luck, T
As a side thought your tune was set up for the new MAF, correct?
Old Jan 18, 2007 | 03:23 PM
Robert Francis's Avatar
You made a lot of changes at the same time - and as others have noted, it's not possible to tell which one(s) are causing your problems. Assuming your trucck ran fine before, I would suggest you take yuour time and go back and review every individual change you made, one by one, until you're sure that everything is properly installed and hooked up. You had to release several vacuum lines etc in doing all this - and perhaps one didn't get hooked back up or improperly hooked back up or an injector line is loose, etc. As others noted, when installing the Accufab, you need to check your TPS voltage - do a "search" on here for "how to's." With the pulleys you installed and the ported blower - .040 gap on your plugs would normally be excessive (most with the pulleys you installed and ported blower would be using around .032 - .036) - however I'm not familiar with running "Brisk" plugs so maybe thats whats recommended for them.
And if you need to make sure your "tune" is the right one for all the changes you've made - including the 4:10 gearing. I would suggest "you" talk to the person you got the tune from and make sure they understand "exactly" all the changes you've made - there's a good chance they could enlighten you quickly.
Old Jan 18, 2007 | 06:52 PM
2-tone-L's Avatar
Thanks for all the input i contacted the tuner and he had me run the live link3 while i was driving and is going to send me a new tune if that don't work i guess i will have to go throuh each mod
Old Jan 18, 2007 | 09:04 PM
I also agree with Rob, while I've never run brisk plugs a .40 gap does seem wide.
