5.4 internals
Old Jan 15, 2007 | 08:11 PM
BABA4488's Avatar
5.4 internals
Hey all you L guys out there. I was just wondering if the lightning 5.4l is has the same internals that my 2006 f150 has. Obviously it has the stock eaton blower on there but what about the internals....i can't seem to get an answer on this one. The reason I ask is cuz i want to get my 06 f150 HD blown but want to make sure im not gunna blow anything up under the hood
Old Jan 15, 2007 | 09:53 PM
kwilt's Avatar
i highly doubt that they are the same...the 06 motor is a entirely different motor
Old Jan 15, 2007 | 11:34 PM
Klitch's Avatar
i think its different bud, the crank is usually higher quality, so are the rods and pistons.
Old Jan 16, 2007 | 12:33 AM
Neal's Avatar
Cool
HI!... The "L" 5.4 longblock and the N/A 5.4 longblocks are the same except for the pistons. The Lightning 5.4 has forged 8.4:1 compression pistons. The N/A 5.4 has HYPEREAUTECTIC 9.0:1 pistons. Most of the older 5.4's had a forged steel crank, but FORD started swapping in some cast cranks after "02" here and there. Not sure if the new 5.4's have cast cranks now. Both my "98" and "99" 5.4's both have forged steel cranks. The forged crank is good for 900H.P (flywheel). The only thing that changed on the 3-valve 5.4's is the heads and intake manifold.
Old Jan 16, 2007 | 12:54 AM
BABA4488's Avatar
Dam Neal you really know your stuff...I was just reading on wikipedia how Ford started strenthening the pistons in 2003 for the L's. In 99 the Ls put out 360 HP and in 01 they tweaked it out so they could produce 380...then after doin this they changed the heads and made more spark plug threads. And like you said they changed cranks in 02. Neal IMO you know more about 5.4 internals than anyone on here...and i was wondering if you think the 2006 5.4 3v heads are as strong as or stronger than the 2003/04 L heads. And if you had to guess, do u think the 06 5.4 3v have forged cranks or cast cranks??????
Old Jan 16, 2007 | 01:17 AM
Neal's Avatar
Cool
HI!... Well the new 3-valve heads will outflow the P.I heads no problem. I have a few buddies that work at the FORD engine plant here in WINDSOR where your engine was built. I'll ask them if FORD is using a forged steel crank in the new 5.4's or cast. I bet it's still a forged steel crank IMO.
Old Jan 16, 2007 | 08:03 PM
BABA4488's Avatar
Thanks man I be really interested to know...do u that a casted crank has any advantages over a forged steel crank?
Old Jan 16, 2007 | 09:53 PM
Neal's Avatar
Cool
HI!... CAST crank is 1/2 as strong ast a FORGED steel crank.
Old Jan 19, 2007 | 12:50 AM
black f150 offroad's Avatar
the 3v 5.4s have higher compression then the 2v , the pistons also have a longer skirts
