A/F Gauge hook up?
Old Oct 2, 2000 | 10:31 PM
JIGAWATT's Avatar
Question A/F Gauge hook up?
Does anyone know for sure which wire (color) to tap into on the O2 senser?
Thanks Kevin
Old Oct 2, 2000 | 11:12 PM
FORDSALES's Avatar
Post
Kevin
Did you end up getting one of the re-designed A/F gauge??
Jim@FordMotor.cc
Black 00, 4.10's, SuperChip/R9, super whites, Airaid w/10" Big Mouth, Mobile1 w/FilterMag, chrome wheels, AIM 2" drop, clear corners
2000 E320, 1993 Cobra R, 1959 Corvette,
1949 Plymouth Coupe
Old Oct 2, 2000 | 11:18 PM
JIGAWATT's Avatar
Wink
YES-
Looks cool
Hey I'll be in Ontario on the 10th for 2 weeks. Maybe we can hook up some time
Old Oct 3, 2000 | 12:03 AM
Slick X's Avatar
Post
Black wire on passenger side o2 sensor near the headers.
97 expedition 4x4-3.73LS 5.4 leather cd changer husky floormats 17" eagle alloys-Painted "starboard" running boards-Custom Wet Okole seat covers with "Expedition" logos-egr painted fender flares-Painted ventvisors-Bug deflector- 5% window tint-Chrome warn brushgaurd with xd9000i winch-Ion driving lights-Piaa 520 Series Crystal Ion coated Driving lights-KENNE BELL BLOWZILLA SUPERCHARGER-Dual 4" chrome tips with dynomax superturbo muffler-Jba headers-3x10 inch Mtx blue thunder subs-1x12 inch mtx blue thunder sub-Rockford fosgate 1100 watt amp-2 Alpine 500 watt amps-Panasonic day/night reciever-4 polk 5x7 speakers-2 pioneer truck box speakers-3 12 inch neon blue tubes under all seats...
Old Oct 3, 2000 | 12:37 AM
FORDSALES's Avatar
Post
JIGAWAT
Let me know when you are going to arrive
Jim@FordMotor.cc
1949 Plymouth Coupe
Old Oct 3, 2000 | 08:18 AM
jarmstro's Avatar
Post
Slick X,
Why on the passenger side? The Gauge(s) will be in a piliar mount on the drivers side. If it is indeed the black wire on the passenger side there has gotta be a black wire on the drivers side.
I too bought one of the re-designed A/F gauges with the LEDs. Now all I need is get "the right color" 2 gauge pod so I can install it along with a boost gauge.
John Armstrong
2000 Red Lightning
** Chipped by Swanson Performance
** http://www.swansonperformance.com
Old Oct 3, 2000 | 10:08 AM
Hwy_2_L's Avatar
Post
Couple of questions on this:
1) We are talking about the O2 sensor between the header and the cats and not after the cats, correct?
2) To wire the light in the meter, anybody have any idea where to wire it in so it works on the dash light dimmer?
Rick
Old Oct 3, 2000 | 10:17 AM
jarmstro's Avatar
Post
Hwy_2_L,
That's what I would like to know. The 'Ls have 4 O2 sensors. So.... where should we plug the wire into?
The light on the meter should be no problem. Your fuse box is on the left side under the dash. You can go to one of the auto parts store and get one of those things that fits in where one of the fuses that the dimmer controls. Like the dash light.
John Armstrong
2000 Red Lightning
Old Oct 3, 2000 | 04:54 PM
SVT54SC's Avatar
Post
I got one of the mod'e gauges too, but mine don't have the wires or the socket for the light. does any your yours have it?
Tt
Old Oct 3, 2000 | 05:04 PM
Slick X's Avatar
Post
Hello everyone. I made a mistake in saying passenger side. It should be the driver side o2 sensor right below the collector on the header. The black wire is before the harness from the o2 sensor ends. After that it turns into a red wire with a black stripe. You can wire it up by the pcm but it is too difficult to find the wire there. I carefully stripped the insulated black wire back and ran the autometer wire piggyback off of it. For the power, you can hook the wire to any control in the fuse box which turns on with the ignition switch. I would hook it into the transmision control fuse or Rap module fuse.
Old Oct 3, 2000 | 05:13 PM
jarmstro's Avatar
Post
SVT54SC,
I bought one of these shown in URL below with all the ledsit is called the Intellitronix. Select "products" near bottom when site comes up. It has 3 wires, hot, ground and one for the O2 sensor.
I'm real surprised you do not have wires unless it is a pressure gauge and it does not come with a light in it.
http://www.gadgetseller.com/gauges/
John Armstrong
2000 Red Lightning
[This message has been edited by jarmstro (edited 10-03-2000).]
Old Oct 3, 2000 | 05:19 PM
SVT54SC's Avatar
Post
I have the three wires for the O2 hookup (black, red, violet) but not the white and black wires or socket for the light. I got the, 5775 -- Phantom (White Dial, Black Bezel).
Old Oct 3, 2000 | 06:11 PM
Hwy_2_L's Avatar
Post
jarmstro - I don't have the A/F gauge yet, just ordered it yesterday, but what you are saying makes sense. The A/F (5775) is a light display gauge so it stands to reason that it doesn't have a backlight. The boost gauge (5703)on the other hand does or should have a backlight that will need to be wired.
Rick
[This message has been edited by Hwy_2_L (edited 10-03-2000).]
Old Oct 3, 2000 | 07:36 PM
FORDSALES's Avatar
Post
I got the Ultra-Lite which has three wires, red, black and purple.
I have had mine now for sometime and can't wait until Lo-Tek gets its color correct for the pillar pod.
Jim@FordMotor.cc
1949 Plymouth Coupe
Old Oct 3, 2000 | 09:21 PM
Jason Zaluski's Avatar
Post
Just doing full gauge for my twin turbo build up. I got a full set of the new Pro-Comp Carbon Fiber gauges by Autometer... they are awesome looking..... but that's beside the point. I've got the A/F with LEDs, and ran into a similar problem as you guys. You do usually want to monitor both left and right header output seperatley. I purchased a toggle switch and got the black from each O2, and ran it to the toggle. Now I can switch it one way for the right side, the other for the left. Simple as that :-)
1995 F-150 Regular Cab Flareside w/ 302 V8... Mods: Mass Air, K&N FIPK, Dual Exhaust (no mufflers), Lund Premier Tonneau Cover, Motorsports 9mm Plug Wires, full JL/Kicker/Pioneer system, Autometer 5" tach, Superchip, Precision Gear 3.73s, TD Chrome Diff Cover
Best 1/8th ET: 10.4107 @ 65.9587 MPH
The F-150 Resource Guide
The F-150 Resource Guide-- a site dedicated to 1987 through 1996 F-series trucks.
