belt slip update
Old Sep 27, 2000 | 01:55 PM
JeffsLightning's Avatar
Post belt slip update
I have the blower belt slip and thought I could get a Goodyear gatorback belt to try and help with the slippage. I can't-- here is their response.. Thanks for requesting Goodyear Gatorback belts for your Lightning. The
belt you need is Ford p/n XL3Z-8620-BA, or Motorcraft p/n JK8-667. This
belt is an 8-rib Poly-V belt that is 66" effective length (66 3/4" outside
length).
At this time we do not have that particular size in our replacement line.
We go from 65.2" to 67.5", with nothing in between. I will forward this
request to our marketing department with a request that they consider
adding this size to our line.
Again, thanks for requesting Goodyear Gatorback belts.
Sincerely,
Clay Shepherd
Applications Rep
Goodyear Tire & Rubber Co.
99.5 red Lightning
13.2@103
jcks@home.com
[This message has been edited by JeffsLightning (edited 09-27-2000).]
Old Sep 27, 2000 | 02:28 PM
JoeLightning's Avatar
Post
I discussed this before, but I really doubt that you blower belt is slipping. If you are experiencing a belt slipping type noise then it is likely the main accessory belt. Sal posted that a new belt has been produced for those who've had this problem. Check it out at: http://www.powersurgeperformance.net...ML/000038.html
If you still insist that your blower belt is slipping, please explain how you 'know' this.
Joel.......
99.5 White Lightning,
SVT # 0056
Old Sep 27, 2000 | 02:59 PM
Post
I'm assuming it is blower belt slippage. The thread from Sal looks like it is talking about cold start noises from the belt. Mine makes the noise hot or cold when going into OD after full throttle acceleration. It sures sounds like a belt chirp when this is happening. I thought I would just try another belt to see if it stops. I have had good results from other gatorbacks that I have bought for my Cobra.. if anyone else would like to chime in again on this noise please do..
Old Sep 29, 2000 | 07:41 AM
Daves00L's Avatar
Post
Jeff:
i have same exact problem, and have taken to the dealer 5 times now. i put on a Gates belt, much better than Ford part (part number K080660). still have noise. i am going to try Sal's broadcast message at the dealer, and see if i can get the accessory belt replaced. Good Luck - will let you know
Old Sep 29, 2000 | 05:52 PM
ZorPrime's Avatar
Cool
yes the Gates belt is .2 shorter than the stock belt."Tighter is Better!!!"
Old Oct 1, 2000 | 09:41 AM
Daves00L's Avatar
Post
ZorPrime:
Ever since i put the Gates belt on, the truck makes boost alot faster, and more (higher)boost to boot. runs like it has a chip. i suppose the Ford part, being longer and looser, did had some slip at supercharger.
Old Oct 1, 2000 | 09:50 AM
lightning's Avatar
Post
Dave is the part #K080660 the Ford # or the Gates? Thanks Dennis
Old Oct 1, 2000 | 10:04 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Question
Lightning,
I would gather the part number is for the Gates as it does not fit Ford's numbering convention.
Zor and Dave,
What was your source for the Gates belt? and cost?
Brake Late, Dive Deep
Speedin Bob
'99 Red Lightning #2504, 6/17/99
NLOC # 438
13.56 @ 100.89, 1.97 60' of F-1's
JL Ram Air (awaiting install), R9 Chip,Keyless Entry, Retrax Bed Cover, Shackles, Wet Okoles, FilterMag
Autophysics filter FOR SALE [9" x 3.5" Red Trim]
[This message has been edited by Speedin Bob (edited 10-01-2000).]
Old Oct 1, 2000 | 10:40 AM
ZorPrime's Avatar
Post
Bob,
cost 33$ list for 52$
Lightning,
That is the gates part#
Old Oct 1, 2000 | 01:36 PM
Post
Zor,
source??
local auto parts store or Summit, Jegs, etc?
Old Oct 1, 2000 | 02:44 PM
ZorPrime's Avatar
Talking
Local auto parts store.
Jegs or Summit may carry them..i dunno.
Old Oct 1, 2000 | 08:02 PM
Post
Zor,
Thank you sir....
Pep Boys dread my arrival. All the more to corn-fuse them with.
Old Oct 1, 2000 | 10:24 PM
super dave's Avatar
Question
How hard is it to remove and install the new one?
Old Oct 1, 2000 | 11:18 PM
ZorPrime's Avatar
Talking
All it takes is 1/2" Drive Ratchet,pull down the tesioner and pop the old belt off and around the fan....put new belt on the same way you took the stock one off.
Old Oct 2, 2000 | 01:07 AM
Post
So I guess the belt is slipping.....thanks for the info on the Gates belt..
