Service Engine Soon---Strange question
Old Oct 2, 2000 | 08:41 AM
Brian K's Avatar
Question Service Engine Soon---Strange question
Everyone,
Over the last 1 month or so, everytime I put gas in the truck the "Service Engine Soon" light comes on. As per the manual, Bad Gas, improper fuel cap operation or low gas can cause this.
After 3 cool/warm/cool cycles, it goes away.
I have filled up from different stations, Texaco, Exxon and Amoco all with the same results.
I have had the superchip since feb 00 and its never happened before this.
Is it posssible that I have a faulty gas cap or there is some sensor in the tank causing this??? I would think if it were bad gas or chip, the light would stay on all the time.
I am hesitant to take it to the dealer for anything because of their past service record with the L.
Any suggestions???
Thanks in advance,
Brian K
kimmel_brian@prc.com
thedink@ix.netcom.com
99.5 Black - Born 5/17/99
  • 13.619 @ 100.28 (8.72 @ 84.55)
  • Tinted Windows
  • PSP Intake
  • Clear Corners
  • Autometer "Phantom" Boost Gauge
  • SuperChip "FlipChip" TRAC
  • Bedrug
  • Alpine Audio w/MB Quarts all around
  • Tow Package
  • Mobil 1
  • Electric I/C Fan
98 Acura 3.0 CL Daily Driver:
Old Oct 2, 2000 | 10:02 AM
jarmstro's Avatar
Post
Start at square one... pull the chip, after you disconnect the battery. Then see what happens.
Make sure ACT Sensor plugged in OK(see you have a PSP filter).
If light continues to come on gas cap not too expensive.
John Armstrong
2000 Red Lightning
[This message has been edited by jarmstro (edited 10-02-2000).]
Old Oct 3, 2000 | 12:06 AM
pvteye's Avatar
Post
You may be overfilling it. Had a Lincoln Mark VIII that did the same if I filled it to far up the neck.
Short Fill next time and see what happens.
Rex
