What happens when you run shorter rear tires?
Old Sep 28, 2000 | 07:01 PM
WA 2 FST's Avatar
Question What happens when you run shorter rear tires?
For those that run shorter than stock rear tires (whether on the street or at the strip):
1) does the computer make the trans shift prematurely? I know on some of these late model vehicles, the trans will be programmed to shift based on MPH as much as RPM. So, if you had a shorter tire, in theory, it might shift at too low of an rpm.
2) any thing else happen with the trans shifting differently than normal when you run shorter tires?
3) can the EEC be reprogrammed for a shorter tire, or can a chip take care of this...like if you installed different rear gears? I'd hate to have the speedo off that much.
I would really like to do something with a wheel/tire package on my truck, but a 345/35-18 is a full 1" shorter than stock.
Thx.
Wes Tarbox
90 LX 5.0 (10.69 @ 134.7)--597rwhp/590rwtq
96 Cobra (12.34 @ 115.8)--392rwhp/433rwtq
99 Lightning (13.20 @ 103.8)--364rwhp/444rwtq
00 Expedition XLT 5.4
http://members.aol.com/Wa2fst/index.html
Old Sep 28, 2000 | 07:02 PM
BABolt's Avatar
Cool
You run up hill!
BABolt
SVT#290
Old Sep 28, 2000 | 07:53 PM
reality1's Avatar
Post
Wes,
Just have chip reprogrammed for this
Old Sep 28, 2000 | 07:57 PM
BABolt's Avatar
Talking
Wes
I know for a fact the the 2000 EEC can be reprogramed for both a gear change (3.55 to 3.73) and tire size. I have done both. If you have a tire disparity of 1 inch or greater front to rear you can set off ABS codes. Yes I would like to have run 345's but I would prefer a 40 series. Running a lowered Lightning with 35 series in the front here in Michigan would be a JOKE. We have the worst roads in the nation. Whole cars fall into pot holes and are lost for days. You only find out about it when you hear of the missing persons report. I quess if I wanted to turn my Lightning into a static work of art I could put 35 series tires on it. I envy those of you that have nice highway conditions.
BABolt
SVT#290
Old Sep 28, 2000 | 08:03 PM
noelvm's Avatar
Talking
BABOLT. Do you or anyone know if you can reprogram a 99 for different tire sizes. I am in the process of changing tires to one that is 30.4, 2 inches taller than the f1s but with a 10" rim. (See, I do listen).
noelvm
Old Sep 28, 2000 | 08:21 PM
BABolt's Avatar
Talking
Noel
I need to check on the 1999. Will get back to you.
BABolt
SVT#290
Old Sep 28, 2000 | 08:44 PM
SilverBullet's Avatar
Post
Yes, you should be able to program a 99 for tire size.
Old Sep 28, 2000 | 10:05 PM
WA 2 FST's Avatar
Post
Thanks guys.
BABolt, thanks for the info about the 1" disparity b/w front and rear. I was considering the 345/35 in rear and 295/35 in front, but that's a full 1.5" difference. Didn't think about the ABS.
And, yes, we have awesome roads down here in the N. Dallas suburbs. I will never complain about how the roads are kept here.
Wes Tarbox
Old Sep 28, 2000 | 10:10 PM
DreaminAboutL's Avatar
Thumbs down
What'll look goofy Wes... unless you lower your L... oh wait, your L is lowered... never mind.
[This message has been edited by DreaminAboutL (edited 09-28-2000).]
