CHIP PROBLEMS
Old Sep 15, 2000 | 07:43 PM
Bigdaddy's bolt's Avatar
Question CHIP PROBLEMS
Istalled R/9 chip yesterday. First try won't start took it out cleaned conection some more try it again. This time it starts runs ok for a half-mile shuts off at a traffic light. People stop to help push it out of intersection,imbarrsing.Won't start remove chip to get it home clean it some more put it back in for the third time. starts up runs ok for 5 seconds,then stalls won't start.Fourth try,take it out clean it some more, won't start.Called Mike Troyer he says sounds like it's not clean enough,send it back to me and I'll check it,I try cleaning it one more time,won't start. I'm afraid to scrap anymore should I send the computer back to Mike w/chip. BTW installed pro m last week. Any help?
Old Sep 15, 2000 | 07:49 PM
littleredL's Avatar
Exclamation
You have to tape it in .The same thing happen to me.I closed the door and it stalled.I reached up and pushed the chip back in and it started.Take the computor back out and tape it in .I did that and worked.
Old Sep 15, 2000 | 07:50 PM
Post
I had it taped.
Old Sep 15, 2000 | 08:49 PM
Fast Gator's Avatar
Post
BigDaddy---I myself, installed a chip last week. Don't know your age, but, if like myself, the eyes are slowly letting us down. Now that I said that, I cleaned my contacts very thourghly (?) twice then three times. Still no start. Finally got a magnifying glass out, finished what I started. Truck starts and runs like a scalded ape. Getting the dreaded glasses. Hope this helps you.
99 Black#1940 Modified Airaid box Pro-M 80 Swanson Chip Wet Okole's Loud Clunk Bedrug Clear corners 2" Aim drop 2nd set well worn F-1's 100 W Xenon Fog Lamps
Old Sep 15, 2000 | 09:18 PM
Moses's Avatar
Cool
Hard to believe how picky chips are to run. Had to clean mine about 4 times, (last two with the glasses on ).
Your case, does sound like she's popping loose and should giver a lil duct tape. (never leave home without a roll or two)
2000 Lightning (Red)
SHM Chip and Mass Air
SHM Blower Pulley
378.2 @ 5100 HP
445.0 @ 3600 ft-lb (before pulley)
Kill Count = 28 suckers picking rubber off their teeth.
SHM powered - www.seanhylandmotorsport.com
'99 Cobra - SHM engine, Vortech supercharger, and to many other mods that my wife don't know about.
Old Sep 15, 2000 | 09:34 PM
reality1's Avatar
Post
Bracket can get in the way also...Just two 8mm bolts, (a little knuckle scrape to get at top one)...remove and take out curved lip at top, check how chip seats in bracket before reinstalling.
Old Sep 15, 2000 | 09:38 PM
JoeLightning's Avatar
Post
Bigdaddy, dig you bend the 2 upper tabs on the computer mounting bracket flat so that they wouldn't interfer with the superchip. The first time I installed mine I used tape. However in trying to force the computer into its mounting bracket so that the black clip would work below the chip, I managed to force the chip out a little as the tape just gave way. I had a no start condition. I took the computer out again, removed the bracket (watch out for the sharp edges up there), and flattened the two tabs that interfered.
Good luck.....
reality1, I always find it amazing that across the county two people like us could be typing the same thing at the same time
Joel.......
99.5 White Lightning,
SVT # 0056
[This message has been edited by JoeLightning (edited 09-15-2000).]
Old Sep 15, 2000 | 10:03 PM
Ryan2KRedL's Avatar
Post
Big Daddy,
Clean it again man! Make sure to get between each of the contacts with a small screwdriver or similar tool (like an ice-pick). Make sure you gently clean the contacts but don't gouge them! Rub them with your finger and you should be able to tell the difference. Lastly once installed put a piece of tape across the chip to hold it in place.
Good luck man, I just installed mine tonight and LOVE IT!
Later,
Ryan Tutor
Ryan460@interpath.com
  • 2000 Red Lightning
  • 13.94 @ 99.60 mph - stock 9/8/00
  • Superchip R9 installed 9/15/00 - Holy Tire Smoke Batman! :-)
  • Awaiting UPS arrival of Airaid box/Autophysics 10" filter (by 9-20-00?)
    Then it's track time again!
Old Sep 16, 2000 | 10:18 AM
Post
I'm 44 and I had my glasses on,even took it out into sunlight with a magnifying glass.I'm starting to see copper,I'll go over it once more,and check that bracket under the dash.Can you scrape to much? Thanks for the help.
Old Sep 18, 2000 | 10:26 PM
Ryan2KRedL's Avatar
Post
So Big Daddy did you get it going?
Old Sep 18, 2000 | 11:17 PM
Post
Cleaned it again,with my glasses on,took the bracket out and flaten it, my hand's raw, no start. Sent the chip and ECM to Mike T. this morning, six trys no go. I'll be without the truck for a few days but hopefully he can help me out and I'll just plug it in and go.
Old Sep 19, 2000 | 01:32 PM
Neroni's Avatar
Post
Bigdaddy,
I had the same problem with my chip sent it back to Mike and they replaced the chip and no more problems.
2000 Black Lightning, Line-x, Roll-N-Lock, Air-raid, and super-chiped,
2 chamber Flowmaster MUFFEL-X.
Old Sep 20, 2000 | 07:07 PM
Daves00L's Avatar
Post
BigDaddy - we met at Mccafferty Ford when we both were getting our L's fixed...
Just got the CUX2R9 chip also. let me know what you find out. when you say you will be without your truck for a few days, does this mean that when the Superchip is not installed, the truck will still not start ? this really worries me.
Daves00L
Old Sep 20, 2000 | 08:20 PM
blackbolt's Avatar
Cool
Big Daddy,
Where in Philly are ya?....I live out in the roaming burbs of Willow Grove...Wondering if you have hung out at Red Lion Rd. or done any racing at Atco or E-town...Just being noosy...
Steve
99.5 Black Lightning
Truck #2215 of 4000
13.78@99.85m.p.h.
Bed Liner
Water Wetter
A.R.E. tonneau
Mobil 1 Synthetic
Smoked Driving Light Covers
Old Sep 20, 2000 | 08:36 PM
clill's Avatar
Post
Dave, he also sent his computer in. Yours will start without a chip. My chip is being redone now and it runs fine without it. A little slower though.
