engine falter when starting?
Old Sep 15, 2000 | 03:51 AM
axe's Avatar
axe
Post engine falter when starting?
Has anyone experienced the following on a warm start?
Key turns, the engine begins to start up, then falters, but then starts successfully. It has never failed to start, but that falter before starting is troubling.
This has happened to me several times already, only on warm starts.
Any ideas what the problem is? I looked in the FAQ and did a search but didn't see anything that looked like what I'm experiencing.
Thanks!
Old Sep 15, 2000 | 10:48 AM
shonut's Avatar
Post
Looks like a similar problem some of us are having. Do a search on throttle position sensor in the L forum. In short, you need to remove this, clean, and replace. Sensor is located on front of drivers side head facing forward. Only sensor there with a wire. Disconnect wire, remove the one bolt, and slide sensor out for wipe down. Replace in reverse. I have had to do this 3 times in 8000 miles. Anyone with a permanent fix or cause would be great.
Old Sep 15, 2000 | 11:28 AM
Q ship's Avatar
Post
what are you wiping away? Just wondering if some silicon spray would help prevent build up of whatever it is.
Old Sep 15, 2000 | 11:43 AM
Silver-Y2K-SVT's Avatar
Post
Shonut:
Aren't you actually decribing the CAM position sensor? This is the bolt located on the driver's side head and the one that causes starting problems when fouled with oil and other crud.
Silver Y2K Lightning
Bone Stock w/ Duraliner, Ford Hitch Cover
Silver (matching) Y2K ML320 Benz
Burl (ML430) Shift ****
Beater 1992 Grand Prix
Commuter Mule
Old Sep 15, 2000 | 01:18 PM
cobra99's Avatar
Post
Does anyone have any picture they can post.
Old Sep 15, 2000 | 02:00 PM
axe's Avatar
axe
Post
I only have 3000 miles on my truck. Has anyone taken it to the dealer as a warranty concern?
Old Sep 15, 2000 | 02:55 PM
SVT-Snake's Avatar
Post
Mine just did it about 15 minutes ago. Only 4900 miles on it. Doesn't seem anything to worry about, shouldn't hurt performance right?
Old Sep 15, 2000 | 04:00 PM
Spiro99SVT's Avatar
Post
axe,
Mine has been doing this since new, I now I have 25K on the beast. It wont do it everytime,but it does it.
Spiro
Old Sep 15, 2000 | 07:33 PM
Wheels's Avatar
Post
I've seen the same problem since day 1 or thereabouts. After 10,000 mi doesn't seem to be a problem.
W
99 Lightning
Bedrug
LoRider Hard tonneau (w/remote unlock)
PSP filter
Bassani Full system
Superchip, PSP chip, Swanson chip
Alpine DVD, CD changer, V12 amp, 2 JL 8" subs, 6 tweet in door, JL 5x7 in rear
Old Sep 16, 2000 | 12:15 AM
shonut's Avatar
Post
Sorry for the confusion. Yes, I was thinking of the CAM position sensor. When I clean mine, there is no indication of buildup other than a thin film of oil. When I do clean it, it does solve the problem for a couple of thousand of miles.
Old Sep 16, 2000 | 12:29 AM
DreaminAboutL's Avatar
Thumbs up
Interesting... my L started doing this with less than 2000 miles on it?! Thought it was just vapor lock.
-Dreamin
