Goodyear 28 11.50x16 Slick
Old Sep 10, 2000 | 01:49 AM
Caka's Avatar
Post Goodyear 28 11.50x16 Slick
Just heard tonight that Goodyear makes a motorcycle racing slick that just might work for our trucks. 28x11.50x16 Anyone know anything about it?? I'll try to research it more.
99-White
6-9-99
#2163
Pro-M 80
PSP chip
Full Bassani
F.R.P.P. single blade T.B.
clear corners & rears
Lonestar spray-on bedliner
white Bugflector II
1/4 13.47@102.50
1/8 8.67@81.33
367rwhp
436.8rwt
yesuah@flash.net
Old Sep 10, 2000 | 08:47 AM
crush69's Avatar
Post
Allready checked that out and it will not work. They have a load rating of about 400lbs a tire. It wouldn't be a wise decision.
Shane
Old Sep 10, 2000 | 10:37 AM
Ryan2KRedL's Avatar
Post
Hey Caka, can you give me any performance improvements with the parts you put on? Specifically, how much did each part help you at the track? That Bassani exhaust is pricey and I've heard really doesn't make much difference (except for the headers) is this true? Thanks.
  • 2000 Red Lightning
  • 13.94 @ 99.60 mph - stock
Old Sep 10, 2000 | 11:29 AM
Fast Gator's Avatar
Post
While I was at a friends garage installing my Pro-M and chip, a fellow that owns a speed shop came by. In talking to him, he stated that Goodyear makes a street drag slick that could be used for our trucks. Of course I wanted an 18 inch, to fit the stock rims. He said he would check and get back to my friend. If anything becomes of this, I will post and let everyone know.
Old Sep 10, 2000 | 01:18 PM
noelvm's Avatar
Talking
MT ET Streets has a great size tire that I would really like to try on the L. Its 28x11.5R15. I think this diameter tire would work much better than the 26" most of us are currently running. If we could only find a 15" wheel with enough offset that would clear the caliper. Still looking for the magic wheel.
noelvm
99.5 Red Ligntning, Mobil 1, PRO-M 80 MM MAF/filter, R2 Superchip, Eldebrock 5512 muffler, MT ET Streets, best time (1/8) 8.62, Bugflector II, G&H Lens covers head & fog, 200 WT Pioneer 4 CH AMP, BOSE 301 SERIES IV SPEAKERS (IN BACK)
70 Vette LS-6 454 (gathering dust in the garage)
Old Sep 10, 2000 | 01:37 PM
BABolt's Avatar
Talking
Noel,
Bob and I did this about 4 months ago.
It works and there are others I know that are doing it too. Offset is not the issue. This combination allows you to chose any 15 inch drag slick that you wish.
BABolt
SVT#290
Old Sep 10, 2000 | 02:12 PM
BulldogSVT's Avatar
Banned
Post
what am i looking at here and where do i get a set?
Old Sep 10, 2000 | 06:43 PM
noelvm's Avatar
Post
BABOLT.
I remember your original post but aren't yours custom made and very expensive. If offset isn't the issue what is? I thought the problem was the 15" rim touching the caliper.
Old Sep 10, 2000 | 06:56 PM
Lightning Boy's Avatar
Post
Noel,
15's will not clear the caliper. BABolt had to grind down the caliper and "E" brake bracket to get the custom 15's to work. Andre and Dad did not want to do any grinding so they are working on offsets.
PS. Andre has the rims and will be testing fit soon.
Old Sep 10, 2000 | 07:08 PM
BABolt's Avatar
Talking
Noel,
The wheels and adapters are a shelf item. Yes, there is some custom work that must be done to the calipers / rotors but that is what it takes to fit the wheels. When I did the original research on this I spent several month and spoke with over 20 major wheel manufactures (from A to Z). There was only one wheel that had a large enough Bell opening (14.6 and excelent run out) that could work. I know that there are several other board members here that now use this combination so maybe they might like to add in. I can show you how to do it or if the interest is great enough I can provide the parts.
BABolt
SVT#290
Old Sep 10, 2000 | 07:14 PM
BABolt's Avatar
Post
Just some additional information. You cannot provide enough offset. The bell of the wheel will not clear the Caliper/Rotor combination. Oh! it might if you are building a Getto Cruiser or a Hot Wheel ( I think that Mattel has the option on those). Plus if you are thinking of spacers, Dream On, NHRA will through you off the track.
PS. Yes the first design edition had the calipers reworked. The second design is different to say the least.
BABolt
SVT#290
[This message has been edited by BABolt (edited 09-10-2000).]
Old Sep 10, 2000 | 09:33 PM
noelvm's Avatar
Post
BA
Are you saying the second design does NOT require modification of the caliper?
noelvm
[This message has been edited by noelvm (edited 09-10-2000).]
Old Sep 10, 2000 | 10:20 PM
BABolt's Avatar
Talking
Noel,
The information that I have says that I should not have to shave the calipers. But I still have not checked the stack up yet. I need to put the physical pieces together to do that. If in fact the shaving of the calipers would cause you alarm then this design change would not be for you as it involves the pulling of the rear axles and the refitting of the caliper mounting bracket, modified backing plate and new rotors. To the untrained eye this changed once installed is undetectable.
Old Sep 10, 2000 | 10:51 PM
BulldogSVT's Avatar
Banned
Post
so...are we gonna keep this a secret or what?
Old Sep 10, 2000 | 10:57 PM
noelvm's Avatar
Lightbulb
Instead of going to all this trouble why don't you use or make an offset wheel? I believe it only has to be offset by about 1 1/2 inches which isn't as much as the mex low riders cars seem to have.
noelvm
