Goodyear 28 11.50x16 Slick
Old Sep 11, 2000 | 01:37 PM
reality1's Avatar
Post
BA,
I ran my 28x11x15 Goodyears this weekend. I didn't have digital camera so I'll have to get film developed and send you a picture.
I went with the silver wheels and adaptors, I think they look good, now just need a chip for my CUX2.
99 lightning
red,snuglid
PSP Chip & Filter
12.930 106.1 best
bassini
build date 4/14/99
NLOC # 362
Old Sep 11, 2000 | 02:11 PM
SVT54SC's Avatar
Post
reality1,
Did you have your ECM re-flashed to a CUX2, did the dealer do it on there own or did you get a new CUX2 ECM? Mine was re-flashed by the dealer when troubleshooting the fuel pump failure by a tech. fishing for the trouble. Is the CUX2 better than the CUX1 or is there no real difference other than the addressing of the program?
Tt
Old Sep 11, 2000 | 04:11 PM
BABolt's Avatar
Talking
Jim,
I'll be glad to see your photos. As you know I also run CUX2 and even with all of the mods I run without a chip ( use the chip for drag racing). If you do go with a new chip I would advise that you go to the same source that Dwight is going to.
PS. Just became a dealer for Pro-M and can offer them in kit form (kit includes Pro-M all brackets, custom hose, filter and an oval throttle body for the Lightning) custom colors and or polish finish too.
BABolt
SVT#290
[This message has been edited by BABolt (edited 09-11-2000).]
Old Sep 11, 2000 | 07:28 PM
reality1's Avatar
Post
SVT54SC,
Dealer installed new computer, it is a long story but different codes for Service Engine Soon Light, I am convinced the old computer was momentarily shutting down truck. I'm not sure of difference(s) except chip for a CUX1 will not work in a CUX2. No CUX1s available
BA,
I am sending you and e-mail. As usual, need help on a question.
Thanks Again for all your help with the wheels
99 lightning
red,snuglid
PSP Chip & Filter
12.930 106.1 best
bassini
build date 4/14/99
NLOC # 362
Old Sep 11, 2000 | 07:33 PM
noelvm's Avatar
Talking
Calling REALITY1. You are running the tires I would like to run. I am courious if you could post your 60', 1/8 amd 1/4 speeds/times and if you ran the 26" tires before what difference you see.
noelvm
Old Sep 11, 2000 | 08:54 PM
BRIMSTONE's Avatar
Post
Jim,
Congrats on the successful wheel/slick setup! I would really like to see some pics! I will also need to countersink the adaptors and as far as shaving off of the calipers I am thinking of going with BABolt's trick setup but would like to see how it looks with just shaved off calipers as well. And definitely post your 60' times!! Please e-mail me!
Thanks,
Mike
Old Sep 12, 2000 | 11:57 AM
reality1's Avatar
Post
Brimstone, noelvm,
Should have some 60 ft times as soon as I can get a chip for my CUX2.
Ran the tires this weekend to check them out, but was somewhat underpowered with new computer. Only got two runs but it seems I have to get used to the rpm I can goto prelaunch (brakes now seem to be limiting factor)as I could never use over 600 rpm on the BFGs (that would give me 1.87s to 1.89s)
99 lightning
red,snuglid
PSP Chip & Filter
12.930 106.1 best
bassini
build date 4/14/99
NLOC # 362
Old Sep 12, 2000 | 02:10 PM
BABolt's Avatar
Talking
Jim,
I need to check with Bob (High Risk) he was doing a new setup of the line lock on his vehicle. I will get back to you. I will try to get some photos.
BABolt
SVT#290
Old Sep 12, 2000 | 06:37 PM
SVT54SC's Avatar
Post
reality1,
No joking about the chip not working anymore, I was PO'd that mine didnt I still need to get a reburn to have my beast back. Im going to dyno tune mine at Houston Performance since I have the Pro-M now.
Tt
Old Sep 13, 2000 | 12:09 AM
reality1's Avatar
Post
BA,
mechanic at my dealer said I could run a switch into each solenoid (1 switch, 4 relays) for ABS for line lock for all four wheels. He pointed to box just below radiator reservior, said might get a code for ABS when in use, but not the priority that needs a star tester to clear.
What do you Think?
