01 lightning side mirror help!!
Old Nov 5, 2006 | 12:19 AM
x3sinfull666's Avatar
Exclamation 01 lightning side mirror help!!
does any one know how to change the light bulb on the side mirror?
(it has turning signals on them)
Old Nov 5, 2006 | 07:27 PM
Woodys2000's Avatar
Yeah man it is real easy. Look at your mirror. Just behind the top of the mirror (use a flash light) you will see where the outside painted cover clips into the main body of the mirror. Then using a thin flat tip screw driver push the clip down and ease the cover back just a little. Then, there is another under the mirror, do the same. Then the cover will come off. Then turn the buld and it will come out of it's seat. Pull the buld and put a new one in. Now if your not comfortable with this you can take it some where because I have read alot of guys who messed theirs up. But hey I screw up everything and didn't mess this up.
Old Nov 6, 2006 | 12:09 PM
ws6_guyscrew's Avatar
Originally Posted by Woodys2000
Yeah man it is real easy. Look at your mirror. Just behind the top of the mirror (use a flash light) you will see where the outside painted cover clips into the main body of the mirror. Then using a thin flat tip screw driver push the clip down and easy the cover back just a little. then there is another under the mirror, do the same. Then the cover will come off. Then turn the buld and it will come out of it's seat. Pull the buld and put a new one in. Now if your not comfortable with this you can take it some where because I have read alot of guys who messed theirs up. But hey I screw up everything and didn't mess this up.
Couldn't have explained it better myself
