p1131
Old Nov 6, 2006 | 07:09 AM
skelly454's Avatar
p1131
Hello, just wondering what exactly a p1131 engine code means and how to fix it thanks
skelly454
Old Nov 6, 2006 | 09:38 AM
unclemole's Avatar
P1130 - Lack of HO2S-11 Switch, Fuel Trim at Limit The HEGO Sensor is monitored for switching. The test fails when the HO2S fails to switch due to circuit or fuel at or exceeding a calibrated limit. Electrical:
Short to VPWR in harness or HO2S
Water in harness connector
Open/Shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged PCM
Fuel System:
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
A fuel control HO2S PID switching across 0.45 volt from 0.2 to 0.9 volt indicates a normal switching HO2S.
P1131 - Lack of HO2S-11 Switch, Sensor Indicates Lean A HEGO sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time. See Possible Causes for DTC P1130
Old Nov 6, 2006 | 01:07 PM
promodlightning's Avatar
Damaged HO2S
Damaged PCM
Fuel System:
Induction System:
Vacuum Leaks
PCV system
EGR System:
Leaking gasket
Stuck EGR valve
Base Engine:
Oil overfill
Cam timing
Now that looks like a full days work.
