Lowest Drop with 22 inch wheels.
Old Oct 23, 2006 | 08:26 AM
halflife's Avatar
Originally Posted by BeyondLimitz
Here is mine
that is perfect, what are u running?
Old Oct 23, 2006 | 11:37 AM
birdy111's Avatar
Originally Posted by SVTLIGHTING
Looks sweet birdy 111. Good pic becuase mine is black also so now I will know what it will look like. What size drop is that 4/6 or 3/4? I cant wait to pancake this thing.
it is a 4/6 western chassis drop. worst ride of any car i've ever ridden in. but man did it look sweet!
Old Oct 26, 2006 | 05:04 PM
SVTLIGHTING's Avatar
Well my truck is going in for a drop next week. My local hot rod shop is doing it when they get back from SEMA. I went with a 4.5/6.5 custom kit w/o c-notch reguired which is good becuase I wanted to avoid that. Cant wait to get that thing slammed.
Old Oct 27, 2006 | 11:39 AM
mecca's Avatar
There is no way you'll be able to get away with a 6" rear drop w/o C-Notch.... I don't know who convinced you on that one, but it isn't true. With a C-Notch, the frame is actually stronger. You don't want your axle smacking the frame when you hit a bump without a C-Notch... it wll make you cringe, believe me.
-Mike
Old Oct 27, 2006 | 11:50 AM
Im lowered 2/3 coils up front hanger in the rear, and i already rub on frame and sway bar right before full steering lock. stock rims/tires (16s)
-Patrick
Old Oct 27, 2006 | 11:55 AM
203Cree's Avatar
-Mike
I've ran 6 without a C-notch. You can do it, but you better have some S T I F F shocks to get away with it. I'm sitting at 5 right now, and I've got a notch sitting in the garage, just haven't put it on yet.
It is doable, but it's a PITA.
Old Oct 27, 2006 | 08:45 PM
He said that as long as I dont drive it down side streets and excessive pot hole roads as a daily driver I will be ok. I plan on using it for the track only, with some minor local driving/racing. As long as the axle does not rub on a smooth road I will be happy. I heard nightmares about the c-notch. Im hoping for the best.
Old Oct 28, 2006 | 12:26 AM
Tim Skelton's Avatar
You would have to be nuts to try anything more than about 4" without a notch. NFW you can pull off 6.5". Even with button bump stops, you will be riding them, probably even at rest. Your ride quality will be horrible and the handling dangerous.
Old Oct 28, 2006 | 02:35 PM
mecca's Avatar
Agreed. I drove for a day without C-Notches because I didn't have time to install them. They were very easy to install, once I took my bed off. Strait forward simple install..... take the extra time and spend the extra couple of bucks and do it right.
Old Oct 29, 2006 | 05:33 AM
thanks for the advice mecca, I will def take it into consideration.
Old Oct 29, 2006 | 06:34 PM
Thanks for the advice mecca, I will take it into consideration.
Old Oct 30, 2006 | 11:11 AM
khendrix2374's Avatar
All it will take is one good, hard slam on the bumpstops of frame, and he'll be putting a notch in there.
My truck will hit the bumpstops sometimes... hurts my back!
