Transmission fluid...what would happen if...
What would happen if Redline's racing ATF was put in the transmission instead of the regualar Mercon fluid? What do you guys think? Would damage occur to the tranny with this fluid? I like the idea of this ATF containg no slipperiness additives, producing faster shifts and quicker lock-up, and reducing elapsed time in drag racing. Anybody try this yet?
The following is from the Redline website:
RED LINE OIL
Synthetic Automatic Transmission Fluids
TECHNICAL INFORMATION
"Synthetic Racing ATF is designed for use in racing automatic transmissions which need the positive shift of a Type-F automatic transmission fluid. A higher viscosity compared to conventional Type-F This ATF contains no slipperiness additives, producing faster shifts and quicker lock-up, and can reduce elapsed time in drag racing. transmission fluids provides higher torque converter efficiency at higher temperatures and the enhanced extreme-pressure protection provides five-times better film strength when compared to petroleum ATFs, reducing gear and clutch wear considerably. This product is designed to be used where Type-F fluids are recommended or for racing transmissions which need quicker shifts than provided with Dexron II fluids. This product can also be used in manual transmissions which require ATFs, providing better gear wear and better shiftability, but Red Line MTL® will provide even better wear protection and shiftability. "
RED LINE OIL
Email them and ask, I like the idea if they have something that is compatable with our tranny.
Go Hard or Go home........
*Red 2000 SVT Lightning
*Leer Lo-Rider Bed Cover
*PSP 4 Program Chip
*Wet Okole seat covers
*Adopted 3/29/00
*352RWHP / 432RWTQ with PSP Chip
-98 Mustang GT Convertible with a destroyed 4.6L Supercharged with FRPP Eaton M112 @ 10psi, to many other handling/engine mods to list.....
*PSP 4 Program Chip
*Adopted 3/29/00
