Differential fluid coming out of vent tube
Old Oct 5, 2006 | 12:13 PM
pitstain's Avatar
Originally Posted by TrackBeast
I agree with FG's comments. I just can't see how synthetics could hurt. I only see benefits. In my research the best 75W-140 is either Red Line or Amsoil.
TB
Yea and the guy at Detroit sounded like it was really important to use non-synthetic
Old Oct 5, 2006 | 01:36 PM
LTNDave's Avatar
its not as important to use non-synthen with the tru-tracs as it is with the eaton's- which are still a clutch style assembly. the clutches in the eatons will burn up if a synthetic oil is used as they will 'slip' with the lessened frictional coeffiecient provided by the synthetic oils. For a tru-trac you should be safe running almost any 'good' rear end lube.
Old Oct 5, 2006 | 01:53 PM
TrackBeast's Avatar
Its my understanding that the Ford fluid is a full synthetic. The clutches are the reason a friction modifier is used which works well with any synthetic. I've been using Amsoil synthetic in my rear end for the last 5 years.
Take a look in your F-150 owner's manual: Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant. So much for that theory
TB
All synthetics are good oils but one thing that Amsoil does better is they have lower volatility than anybody else. So less goes up in the air and for engine less in the intercooler. Here's the latest from Amsoil for heavy towing, off road and racing. Don't sell it, just use it.
http://www.amsoil.com/storefront/svo.aspx
Old Oct 5, 2006 | 07:17 PM
bglanden's Avatar
Originally Posted by pitstain
LOL.....inside joke between me and Hostile..... trust me I've met the guy and he ain't that pretty LOL
I've met Rich too, I was just bustin his *****!!!
Bryan
Old Oct 5, 2006 | 10:26 PM
pitstain's Avatar
Ok guys I "fulled it up" with some 75w140 lucas, I know its not full syn, but it'll be leaking out of the seals slowly anyway......
I will keep an eye on it for now....
Old Oct 6, 2006 | 09:13 AM
SVT F15O's Avatar
No Flame suit needed bud......I am going to give it a shot.....I'll pick up some 75w140 full synthetic and see what happens....maybe it will cure my leaking axle seals as well.....
I doubt it will take care of your axle seal problem as that is a pretty common issues with these trucks. It may very well take care of the vent leak though. When you do the axle seals I would look good at all the bearings. Sounds like something is getting hot in there. Otherwise it is probably a fluid level issue. Goodluck, -Mat-
Old Oct 6, 2006 | 12:41 PM
LTNDave's Avatar
Is it possible that it was overfilled?
Pull the factory fill plug on the side of the housing and check the level there, I have used several aftermarket housing covers in racing use and at times have had the x-tra capacity covers cause problems when filled to full capacity. May or may not fix the axle seal issue, worth a shot though.
Old Oct 9, 2006 | 11:54 PM
pitstain's Avatar
well put 500 miles on her with lucas non-syn 75w140 and very minimal leakage....looks like 80w90 was too thin.....I also found my damm brake fluid leak ive been looking for for weeks.......the evidence was covered in diff fluid before but now i was able to find it.
