Need to remount hood scoop
Old Oct 9, 2006 | 03:56 PM
halflife's Avatar
I need to remount my hood scoop. Starts to lift up between 85-100mph. It is off of a mustang. Any advice on the best way to mount it. It does have 2small bolts through the hood to hold it on. I think the rest is just double stick tape or something. What would be best? Some 3m double stick or something else?
Thanks!!!
Old Oct 9, 2006 | 04:37 PM
Falcon11's Avatar
If you want it to stay I'd put something stronger on it. I used GOOP plummers glue on my hood snout pieces.
Old Oct 9, 2006 | 04:53 PM
Neal's Avatar
HI!... I sold over 100 MUSTANG GT hood scoop kits for F-150's a few years back. The best way to mount them is with supplied screws and WINDSHIELD URETHANE. Also it really helps if you cut open the hood under the scoop to allow the incoming rush of air to go somewhere.
Old Oct 9, 2006 | 05:39 PM
halflife's Avatar
thanks, scared to hack my baby.
what happens when it rains and you are driving?
Old Oct 9, 2006 | 05:44 PM
Neal's Avatar
HI!... NOTHING...........
Old Oct 9, 2006 | 05:57 PM
fullboogie's Avatar
Halflife,
I really like that scoop on your hood - great idea! Where did you get it?
Old Oct 9, 2006 | 06:04 PM
halflife's Avatar
Originally Posted by fullboogie
Halflife,
bought the truck with it on, previous owner said it was off a mustang GT.
Old Oct 9, 2006 | 06:09 PM
halflife's Avatar
does it rain in canada or just snow
i would think rain would run up the hood at speed and dump into the engine bay.
Old Oct 9, 2006 | 07:03 PM
Neal's Avatar
HI!... NOPE!.........
Old Oct 9, 2006 | 07:08 PM
halflife's Avatar
Ok, i followed allot of your post and going to say you know better than me!
so did a body shop cut it? or did you take an air saw or something to it?
Old Oct 9, 2006 | 07:48 PM
Neal's Avatar
HI!... I just used a jigsaw with a fine metal blade. The hood is made from aluminum so it won't rust and is easy to cut. I masked off the painted surface so that the bottom of the jigsaw wouldn't scratch the paint. The pattern to cut out under the hood scoop is already there on the under side of the factory hood. When I had that hood on my truck I also filled in between the two sides of the hood with WINDSHIELD URETHANE.
Old Oct 10, 2006 | 07:54 AM
halflife's Avatar
thanks
Old Oct 10, 2006 | 10:18 AM
TampaBlack99's Avatar
Mines a similar scoop but has 4 bolts that hold it one. I also cut the back of the scoop out which stopped the scoop from lifting.
Old Oct 10, 2006 | 11:01 AM
brain bypass's Avatar
it would probably help keep the blower cool if you cut out the hood...
Old Oct 10, 2006 | 11:10 AM
Kinda like this? More of a heat extractor.
http://fordtruckworld.tenmagazines.c...81-album-21392
