Mustang Power Window Relay?
Old Aug 8, 2000 | 09:52 PM
HIGH RISK's Avatar
Question Mustang Power Window Relay?
I know this isn't really Lightning related. But I have a problem with my '93 Mustang and I know alot of you are Mustangers too. The passenger window won't go up or down. Drivers side is fine. Swapped the switches from drivers side to passengers side. Didn't help. All fuses are good. Can jump 12 volts to the window motor and run it up and down.
Does anyone know where the relay is?
HIGH RISK
Old Aug 8, 2000 | 10:26 PM
Trace's Avatar
Post
WOW!
A mustang question that has me stumped too!
You swapped the switches over.. I understand the window won't work using the switch (left in place) on the drivers' side?
Maybe there's a problem inside the door causing the window to be in a bind.
Or, try posting this on the corral's windsor forum. It's flooded with mustang gurus that can probably help. www.corral.net
Good luck!
If you find out the answer, let me know please.
Trace
[This message has been edited by Trace (edited 08-08-2000).]
Old Aug 8, 2000 | 10:41 PM
HIGH RISK's Avatar
Post
Thanks Trace,
I'm waiting on a pass word for corral. Thought maybe one of you guys been through this before.
The pass. side works on the drivers side.
HR
[This message has been edited by HIGH RISK (edited 08-08-2000).]
Old Aug 8, 2000 | 10:58 PM
SilverBullet's Avatar
Post
Posted for you at the Corral.net; http://www.corral.net/Forums/Forum1/HTML/033485.html
HOpe you get a reply...
Steven
Old Aug 8, 2000 | 11:12 PM
Post
From Corral:
The wiring harness for the passenger side door (regarding windows and door locks) runs underneath the dash pretty much where the windshield meets the metal. It then comes down the the driver side kick panel and plugs in to the main harness. The wires are pink. I am sure there are no relays from the passenger door to the driver's side kick panel connection. Hope this little bit of info can help at all.
Old Aug 9, 2000 | 03:20 AM
HIGH RISK's Avatar
Post
Thanks Steve,
I'm glad I didn't get roasted for a none Lightning question.
Old Aug 9, 2000 | 08:56 AM
gp's Avatar
gp
Post
check the wireing in the black boot between the door and kick panel.the continues opening and closeing of the door can break the wires over time.
