need help 22's and a drop pics please
Old Sep 3, 2006 | 09:57 PM
meansvt00's Avatar
Question need help 22's and a drop pics please
ok im having a little issue deciding which tire and what drop to do. i know or at least i think i know that i want 22's.
COULD YOU POST SOME PICS AND INFO
you guys with 22's what size tire are you running.
also what are you using to lower it and how far.
i was thinking 305/40/22
and the tvs but i dont think it will be low enough
so i was thinking hotchkis springs and either lower control arms or drop spindles
some guy seem to be running 295/30/22 which i would think were two low but the few i have seen pull it off well but i dont know how much they dropped it.
also have is the ride on the 295/30/22
i know its alot of info to ask for but i would appreciate it
Old Sep 12, 2006 | 10:23 AM
a Swiss guy's Avatar
Hy!
My truck runs on 22" Zinik wheels with 285/30 Pirellis. The level of the Lightning is stock, but I could install a Airride system. With the 30' I don't must adapt the tachometer. The ride is a little bit more harder, but more than ok.
Many greetings
Steve from Switzerland
Old Sep 13, 2006 | 08:48 PM
JesseSVT's Avatar
1inch front 3inch rear drop - 305/45/22 will fit perfect
2inch front 4inch rear drop - 305/40/22 will fit perfect
3inch front 5inch rear drop - 305/35/22 will fit perfect
4inch front 6inch rear drop - 305/30/22 will fit perfect
295 width will work but i personally like wider tires....def do your drop before you choose a tire tho. i ended up having to buy new tires when i decided a 1"front 3"rear drop wasnt getting the job done.
