Does anyone use an alternative oil filter for more capacity?
I have done that in the past. All you have to do is get the same thread size and O-ring location and as long as the filter length fits, your golden.I think I'm going to open an 820S and go shopping!
I have there origional style oil filter. Well made easy to clean and reinstall. One problem I had was it comming loose and leaking. You can safty wire it, which is what I did. The new style might be better at staying tight. I think it is because of our oil cooler adapter being made of stamped steel, and the o-ring on the CM filter. Hope this info helps. Artie
Originally Posted by ganiman
Dan
HI!... I run a dual oil filter set-up on my truck. Two K&N HP-3001 filters. They hold about 1 liter each. Those combined with my deeper oil pan I have a total of 11 liters of MOBIL 1 in the engine.
I also run a external aux tranny filter as well. Same filter as the oil.
