pullys questions please help
Old Aug 9, 2006 | 11:20 PM
Motrmaniac's Avatar
well whats the differ if i change the top pully or the bottom. all i want to do is changed a pully and just get a dialbo tuner to it
Old Aug 10, 2006 | 07:51 AM
halflife's Avatar
change the bottom, much easier.
Old Aug 16, 2006 | 12:28 PM
04LIGHTING's Avatar
from what ive been told... if you change the crank pully you will gain more torque less hq, if you change the upper pully you will have more hp less torque
Old Aug 16, 2006 | 01:40 PM
LIGHTNINROD's Avatar
When you change the upper pulley, you go to a smaller diameter pulley which can lead to belt slippage. You change the lower to a larger diameter so belt slippage is not a problem(with the proper belt).
Changing either can increase s/c'r boost and therefore, increase torque and hp but I went with just the lower pulley.
Dan
Old Aug 16, 2006 | 02:00 PM
LatemodelRacer2's Avatar
The upper cost just as much or more in the end so why do it plus u get belt slip and possible snout damage.
Old Aug 16, 2006 | 02:04 PM
Tim Skelton's Avatar
You should not listen to that person any more.
The engine knows only pulley ratios. It does not know what combination of pulleys produced that ratio.
