Belt Size Help
Old Jul 30, 2006 | 11:21 AM
04SonicBlueL's Avatar
Belt Size Help
I did a search and turned up no help with belt size. I was wondering what belt size will I need for billetflow 2.76 upper and metco 4lb lower and what belt size after I add the billetflow double pulley snub idler kit.Thanks for any help. Kat
Old Jul 31, 2006 | 08:37 AM
unclemole's Avatar
Hope this helps:
stock length-66"
stock lower/2.75" upper/stock idlers-65.5" belt
stock lower/2.8" upper/stock idlers-?
stock lower/3.5"upper/aux idler w/90mm and 100mm-69"
4lb lower/2.75" upper/stock idlers-
4lb lower/2.8" upper/aux idler/90mm and 100mm-68.5"
4lb lower/stock upper/stock idlers-67.5"(very tight)
4lb lower/3.5" upper/two 90mm idlers-68.5"
4lb lower/3.5" upper/aux idler/two 90mm idlers-69"
4lb lower/3.25" upper/stock idlers-68.5"
5lb lower/3.5" upper/stock idlers-68.5"
6lb lower/stock upper/stock idlers-68.5"/69"
6lb lower/2.7"upper/stock idlers-68"
6lb lower/stock upper/Aux Idler w/two 100mm-69.5"
6lb lower/3.25 upper/69"(tight)
6lb lower/3.5" upper/90mm idlers-69.5"
8lb lower/stock upper/Metco aux idler w/two 100mm-69"
8lb lower/2.75" upper/stock idlers-67"
8lb lower/2.80" upper/aux idler w/two 90mm-69.5"(tab removed)
8lb lower/3.25" upper/stock idlers-68"
8 lb lower/3.5"upper/aux idler w/two 90mm/tensioner tab removed-69"
10lb lower/stock upper/stock idlers-72"
Old Jul 31, 2006 | 12:09 PM
Thanks for the info unclemole. Where did you find this info?
Old Jul 31, 2006 | 11:22 PM
Full Auto's Avatar
How about stock upper, 6 lb and magnum powers idler brace with 90 mm idlers?
Old Aug 1, 2006 | 04:46 PM
SVT_KY's Avatar
Alex, I'll take wild setups for $100 !!!
