red line water wetter/intercooler
Yesterday i almost poured a bottle of red line water wetter into the intercooler filler instead of the radiator filler.
This made me think that maybe this is a good idea?
Does anyone know?
It seems that it wont hurt anything and it should keep the system 10 or 15
degrees cooler.
Does anyone know?
degrees cooler.
My intercooler mix is 80% water/20% antifreeze and a bottle of water wetter.
If you are going to put water wetter anywhere it should be in the intercooler because it's non-regulated and you'll see the most benefit. Your engine coolant temperature is regulated by the thermostat so adding water wetter doesn't do a whole lot for you unless you are having problems cooling the truck.
Originally Posted by SWThomas
Water and Water-Wetter in the I/C for me in the summer. Come winter, I use a 50/50 mix of antifreeze.
i've heard that water wetter when mixed with antifreeze, does virtually nothing. but mixed only with water it is effective.
If you're really interested in Red Line's "water wetter" effectiveness combined with water, with wataer and anti-freeze, etc. - and how water wetter works -check Red Lines website. Gives you all the details on well they say it works under differing conditons and applications.
Artie
