Transmission Question
Old Jun 20, 2000 | 09:43 AM
LSTORM's Avatar
Question Transmission Question
Does anyone else have the problem of the transmission doing a double shift when it is stomped going 80 mph or above?
The truck down shifts, the RPM climb to just above 4,000 (about 1-2 seconds) then shifts up, then shifts down again and holds the gear until 5,000 RPM.
This is really aggravating. The dealer already said that they would not drive it above 70 mph.
The problem does not occur until 80 mph.
Any suggestions are greatly appreciated. Thanks in advance.
Old Jun 20, 2000 | 10:26 AM
WHAT04's Avatar
Post
Yes, mine does something similar to this, although I've never measured it via RPM's. I just figured it had something to do with how I was pressing the throttle, and I wouldn't say it is consistant.
You realize that SVT will recommend that speeds above 70 mph are against the law?!?
2000 Red Lightning Born 3-8-00 / Delivered 3-22-00
22% Window Tint, Clear Corners, MPulse LoPro Tonneau, AIM 2" Drop Shackles, Bed Rug, PSP Filter Kit
'99 Yukon Denali - Silver, Lowered 1", Borbet CW4's, 285/60R18 Toyo Proxes S/T's, Hotchkis AntiSways, Edelbrock Shocks
2000 Red Trans Am Ram Air WS6, 6 Speed - Delivered 2-15-00 - Awesome Looking Car
Old Jun 20, 2000 | 10:35 AM
LSTORM's Avatar
Post
WHAT04,
I was also thinking that it is the way I press the throttle. If I ease into it, then the double shift will not happen. It only happens when I stomp it fast.
Have you experimented with this?
Have you brought this subject up with the dealer.
I would like to know how many other people have this problem.
Thanks for the input.
Old Jun 20, 2000 | 11:27 AM
BLoG's Avatar
Red face
I have a '93 L and that happens for me as well. It seems like it downshifts when I really flog it and then shifts back up for a couple of seconds.
I think I'm gonna go to the local community college and take some auto shop classes
Old Jun 20, 2000 | 11:36 AM
WHAT04's Avatar
Post
I have not experimented with this and no, I will not be bringing it up with my dealer. I already had the tranny replaced and I am happy for now.
I don't see it as a big problem. I'm sure it's a programming issue. (in my opinion, there is WAY TOO MUCH computer involvement in the transmission)
Old Jun 20, 2000 | 03:57 PM
LSTORM's Avatar
Post
TVW,
Thanks for the info. I will ask them to do as you said.
Old Jun 21, 2000 | 12:13 AM
tvw's Avatar
tvw
Post
Lstorm,
Your dealer can troubleshoot under near actual conditions with good safety margins by performing the shift testing on a chassis dyno. If they refuse this simple solution, get another dealer and/or escalate this with SVT. Lightning was specifically built to possess high performance, so FOMOCO/dealer testing and maintenance should match!
-tvw
