Opinions on painting a KB....
What's the common consensus on painting a KB? Good or bad? I've seen that a lot of people have done it and I've also heard from a few people that it causes the heat to be trapped which can adversely affect the intake temps and internal parts. What say you??...
I am in the process of purchasing a Whipple Kit from JDM to import into the UK
Fancied a polished version but was informed the black finished ones run cooler.
Something to do with heat transfer but maybe someone could chime in with the exact facts.
I think the theory is, with polished you loose a lot of surface area for cooling effect. Closed pore theory? If you paint it, I would do real thin coats, or look into anodizing or powdercoating or something like that. I would think the effects would be minimal either way.
Not sure about the theory....but am sure you DO retain tiny bit more heat. When I dynoed after installing the polished KB...my IAT2 temps were not hot at all. So....to keep things in perspective....how much do you actually loose in speed...power....and all else? Who knows. I didn't loose anything.
Moreover...theoritcal science can prove that an elephant can hang suspended from a daisy.
Just a thought.
Just a thought.
