Oil Change
Old May 17, 2006 | 01:46 AM
toslow's Avatar
Oil Change
Ok been looking for like an hour and can't find the answer to my question. What kind of oil is everyone using? I have had my truck for about 3 weeks and according to the sticker it's time for a oil change. I read in the manual and it says to use 5W20. I have never used that I always have used mobil 1 5w30. So anyway what oil and filter is everyone using in your L.
Old May 17, 2006 | 06:17 AM
ARTIE54's Avatar
I run Mobil 1 10w30 from June to Sept. Than change to 5W30 for Oct till May. Have almost 70,000 miles now no troubel and clean as new on the inside! Hope this helps! Artie
Old May 17, 2006 | 08:41 AM
chief40al's Avatar
Mobil one 0-20 or 5-20
Old May 17, 2006 | 11:19 AM
Bill Bell's Avatar
Mobil One 5W-20
Old May 17, 2006 | 12:26 PM
toslow's Avatar
Sounds like Mobile is the winner. Are you guys running regular or synthetic? How bout oil filter? Is the motorcraft one any good or should I go with wix or k&n? How bout castrol synthetic? I was thinking about going 5w20 in that with a motorcraft filter. Later!!
Old May 17, 2006 | 12:28 PM
03BadAzzLghtn's Avatar
Mobil 1 is not the winner..Use Royal Purple my friend!!
Old May 17, 2006 | 01:18 PM
jarmstro's Avatar
Use motorcraft 5W20 which is semi-synthetic and is cheaper than Mobil 1 along with motorcraft FL-820S filter.
Like most of us you probably will change your oil every 3000 miles so why waste your money on synthetic oil.
Old May 17, 2006 | 01:55 PM
chub's Avatar
Motorcraft 5w-20 is what I use
Old May 17, 2006 | 06:37 PM
LightninSVT's Avatar
I have been using Mobil 1 5w30 for 5 years now with no problems. ALL year round. I have tried all kinds of filters though. I usually just pick up a fram or motorcraft. The mobil 1 filter is pricey, and I doubt its any better than the others...
Jon
Old May 17, 2006 | 08:07 PM
SWThomas's Avatar
Mobil 1 5W-30 Full Synthetic.
Old May 17, 2006 | 08:17 PM
Falcon11's Avatar
+1
Old May 17, 2006 | 08:19 PM
PoorSvtMan's Avatar
motorcraft 5w-20 and motorcraft filter... 115k miles and when i pulled the motor after i lifted a head the bearings looked brand new, no sludge or anything
Also autozone sells it by the case.. i usualy by the 12pack case and 2 filters ..Every now and then i buy a few extra bottles just to have around to top off the motor if needed, etc..
Old May 18, 2006 | 01:39 AM
toslow's Avatar
Hmm, I guess I'll go with Motorcraft 5w20 with the motorcraft filter. I been a mobil user for some time now but 6 bucks a quart is crazy!! I may try to find mobil 5w20 non synthetic that 5000 mile stuff and change it every 3K miles. Heck I don't know I gotta make up my mind though cause I'm gonna try to change it friday. Thanks for the input guys.
Old May 18, 2006 | 02:23 AM
MaxTorque02's Avatar
For a dino oil, Castrol and Chevron Supreme are excellent oils. I've been running Chevron Supreme in my Lincoln Navigator and it has 118,000 miles. Good maintenance practice is the most important I also use either the Purolator Pure one filter or the Motorcraft filter.
Old May 18, 2006 | 06:46 AM
SWThomas's Avatar
$36 every 3k miles is worth it IMO. Nothing but the best for my baby.
