Polyurethane Bushings
Old Jun 13, 2006 | 10:21 PM
  #31
Tim Skelton's Avatar
Originally Posted by TrackBeast
. . . Can be quite expensive . . .
Why? Sounds like a low-tech $20 job to me.
. . . I also epoxy coated them to keep them pretty. . .
Dropped mine off at the powder coater this morning.
Old Jun 13, 2006 | 10:42 PM
  #32
TrackBeast's Avatar
C'mon Tim, how much legal advice do you provide for $20?
This has to be done with precision otherwise the ball joint would be on an angle. The shop were mine were done designs casting moulds for Mercedes V-8 engines. The spindles were mounted on a multi-million $ machine. My buddy even corrected the variance in tolerances between the right and left side. Allot of money for such a crude piece.
TB
Old Jun 14, 2006 | 12:16 AM
  #33
captainoblivious's Avatar
Once I had ordered and received them, I voiced my concerns to their tech/sales dept. and their response was that If I was "that" concerned about safety with their spindle with the non-locking slim nut that I should not use it.
I was considering getting rid of the Hotchkis springs/leafs and going back to stock with spindles and hangers to lower it. Maybe I should give Belltech a call and tell them thanks for saving me some spare cash
Old Jun 15, 2006 | 01:46 PM
  #34
FordsRock98's Avatar
The ones on my 2002 stock control arms are badly dried and cracked. They were only on the truck for about a year, but the rubber should dry out the same whether on the truck or not.
Thats what I was affraid of, mine look like powdered rubber
Old Jun 15, 2006 | 02:18 PM
  #35
. . . This has to be done with precision otherwise the ball joint would be on an angle. . .
I'm still not understanding. What would be the problem with even a 1 or 2 degree angle? I certainly had an angle on both the upper and lower ball joints beginning with my first spring swap.
C'mon Tim, how much legal advice do you provide for $20? . . .
Any question that can be answered in 3-4 minutes.
Old Jun 15, 2006 | 07:47 PM
  #36
Black02SVTL's Avatar
You need to machine 1/8" from the bottom of the spindle. Can be quite expensive if you don't have a buddy working at a machine shop. I also epoxy coated them to keep them pretty.
Once I had ordered and received them, I voiced my concerns to their tech/sales dept. and their response was that If I was "that" concerned about safety with their spindle with the non-locking slim nut that I should not use it. At that point it was already at the machine shop and if my machinist friend didn't confirm 100% that it was safe, I wanted to shove them down this guys throat.
TB
Do you have any before/after machining pictures?
Old Jun 15, 2006 | 11:19 PM
  #37
I'd like to see the after pic is also.
This is the before/problem:
Old Jun 20, 2006 | 02:37 PM
  #38
TrackBeast's Avatar
I carefully measured the threaded portion of the ball joint and removed 1/8" from the bottom of the spindle. There was enough thread on the ball joint to remove even more but I decided that this was sufficient. Another simpler option would be to countersink the castle nut. This would work just as well.
The ball joint stem was drilled for the cotter pin and in order to clear my stick on weights on the wheels, the full size castle nut was grinded down a bit along with the stem. This has no effect on the strenght of it all because the strength isn't in the castle portion and the cotter pin is still solidly in place. The spindles were epoxy coated to keep them looking pretty.
TB
Essentially, if you look at the picture in the previous posting and add 1/4 to 5/16" of clearance.
