Oil leaking from supercharger!
Old Apr 17, 2000 | 02:38 PM
Radarlove's Avatar
Post Oil leaking from supercharger!
Well I have the strangest thing happening with my blower. There is a little oil residue/puddle on the top, just behind the pulley. It's very clean and minor volume, but when I wipe it away, it reappears in a day or two. Can't tell where it's coming from! I thought it might be coming from one of the bolts holding the front plate on, but there's no trail. A friend suggested it might be coming from the seal where the pulley shaft comes through.
Anybody out there have this problem?
1999 Red Lightning,
Bed Rug, Soft Cover, Towing package, Super Chip, 50 Series Flowmasters, PSP Filter, Valentine 1.
1996 Kawasaki ZX-11-Candy Red
1996 Honda Goldwing Aspencade. Candy Red
1974 Century Ski-Fury, (454 Mercruiser inboard)
Jsnyder414@aol.com
Old Apr 17, 2000 | 03:03 PM
Speeyuk's Avatar
Post
How many miles does your L have on it? I have a '94 T-bird SC and a little leaking from tbe blower is not bad. If it's coming from the nose cone, I'd have it checked out. It may not be sealed correctly. I dont know if your blower has a screw you can undo to check the blower fluid, but if so I'd do that as well.
Old Apr 17, 2000 | 06:12 PM
Radarlove's Avatar
Post
I only have 6200 miles on it. I have a company car that I drive in bad weather and when I'm out of town. Heck, My L hasn't even been driven in the rain yet.
Old Apr 17, 2000 | 09:23 PM
JIGAWATT's Avatar
Angry
Radar:
My eaton was doing the same thing from day one. If you see oil behind the blower pulley, it's the front seal. NEW BLOWER TIME.
Ford will not replace just the front seal. No problems, it's under warranty.
You can do a little test to see if it was just like mine?
1. Clean blower pulley & blower with brake clean, let dry.
2. Road test for a mile ( do not let it make any boost). Look under hood for any leaks.
3. Raod test again, this time HAMMER IT, make it work hard. MAX BOOST.
On test, 2. you should not see any oil.
On test, 3. If it's like my old one, oil will be all over the place. The pulley sprays oil every where.
Good Luck
Kevin
Old Apr 18, 2000 | 07:42 AM
Radarlove's Avatar
Post
Thanks for the info, Kevin. I appreciate it, and will give your test a try.
Old May 29, 2000 | 06:14 PM
Metallic Blue's Avatar
Banned
Question
Radar,
What ended up happening when you followed Jigawatts advice?
Has anyone else encountered this problem, because I have made a list, and if more then 5 people arrive at the same conclusion, then I make a special mark. This helps the dealerships we all attend to know it's not just a simple "coincidence".
Old May 29, 2000 | 06:41 PM
Super Chicken's Avatar
From: Garden Grove,Ca. USA three block from Disney Land the Second best Ride
Unhappy
My SC Bird had that problem about a year after I got it. Ford just replaced the blower and didn't say a word. I haven't had problem with my L but if you are out of warr. it's part of fuel syst. and should be covered under emission warr.
1999 Red SVT Lightning
#3466 of 4000
NLOC #428
