torque spec for lightning tires
Old May 28, 2000 | 01:10 PM
alphadoggy's Avatar
Post
100 lb./ft.
Old May 28, 2000 | 01:17 PM
littleredL's Avatar
Cool
Thank you for the speedy reply.
Old May 28, 2000 | 01:29 PM
PD Lightning's Avatar
Post
Hey alphadoggy, are you at work with nothing to do!!!;;
just checking!!!
Old May 28, 2000 | 04:25 PM
alphadoggy's Avatar
Cool
Work? Work? Was ist das?
Old May 28, 2000 | 05:59 PM
A-Lightning's Avatar
Wink
littleredL:
Strickly a guess here!
I know for a fact the 99's are 100lbs
The 2000's have bigger studs, assuming they torque a little more than that!
I'm not sure exactly how much tho, I have a 99L
99.5 White Lightning
Superchip
PSP Filter kit
13.42@101.55
[This message has been edited by A-Lightning (edited 05-28-2000).]
Old May 28, 2000 | 09:19 PM
alphadoggy's Avatar
Exclamation
Veddy strange. I have an '00 with the 14mm studs, but I was pretty sure that the spec was still 100 lb./ft. When I was searching for Gorilla locks one of the guys at American Tire pulled a lug nut to size it, and I thought the spec. was stamped on the nut. So, just for the heck of it, I just went out and pulled a nut to see, but there was nothing on it. So I looked through both manuals, and didn't find the spec there, either, although I admit my search was pretty cursory. So, now I'm wondering myself where I got my info, and why I felt so certain of it.
[This message has been edited by alphadoggy (edited 05-29-2000).]
Old May 28, 2000 | 09:33 PM
adp's Avatar
adp
Post
For the '99 L, the torque spec of 100 #ft is stamped on the lug nuts. Hey Peter, what do your nuts say? Oops!
adp#1530
Black '99
Old May 29, 2000 | 12:46 AM
Franko's Avatar
Post
Hey guys,
Previous post from adp specified 150 ft/lbs for the '00 L w/ 14mm studs.
Search under 'lug nut torque'
Sorry, that quote was from 'silverbulletonorder'
Franko
'00 Silver 'L
SST tonneau Cover
Ford aero hood shield
35% tint side glass
clear fog covers
100w Hella 9007's
55w halogen backup lights
Lund back draft spoiler(silver)
Ford tail gate protector
Rubbermaid bed mat
Hidden tailight mud flaps
Alarm w/surprise!
2 MacIntosh 2x100 amps w/Boston Accoustics 6.25 componets Front and 6.25 co-ax rear.
Ford cabin air filter
Ford cam kit w/lower weld
Dual Bullet SS mufflers
Folia Tec red calipers
Ford wheel locks (on order)Gorrilla's were a bust for MY'00
'00 MB E55 Bone stock 5.4 0-60 -13.3 1/4
'00 MB CLK430 cabriolet
Go slow if you must but life without thrust is a bust
[This message has been edited by Franko (edited 05-30-2000).]
Old May 29, 2000 | 12:48 AM
littleredL's Avatar
Exclamation torque spec for lightning tires
I did a search but could not find anything. What are we suppose to torque the lug nuts to on the lightning tires? thanks
Old May 29, 2000 | 04:38 AM
adp's Avatar
adp
Unhappy
Franko,
Searched under 'Lug Nut Torque', couldn't find a reference. I don't own a 2000 L so I can't comment on the torque values. Can you give me a link to the spot where I said that?
Thanks,
adp
Old May 29, 2000 | 07:29 AM
LightningKid's Avatar
Exclamation
M12(99)= 100ft. lbs.
M14(00)= 150ft. lbs.
Thx. Silverbulletonorder for corrcet info!
Posted 4-09-00 under heading:Lug nuts...how tight?
[This message has been edited by LightningKid (edited 05-29-2000).]
Old May 29, 2000 | 10:19 AM
SVT2Go's Avatar
Post
The correct torque specs for both beasties is lister on the LUG NUT.
Just an FYI
Brad
* 99.5 Black Lightning
* Personal Best ¼ Mile 13.82 @ 99.98 Mph
* Ohio Plate SVT2GO
* Sal’s Chip and Filter
* Interceptor Trans
* All three Factory options for 99
* Factory CD Changer
* Class 3 Towing Hitch
* Factory Tonneau Cover
* 8" Bazooka Tubs
* Kenwood 80 watt *2 amp
* Viper 550 Alarm w/ remote start
* 97 F-150 Extended Cab 4.2L V-6 daily driver
Injection is nice, but I'd rather be blown. 99 Lightning, the best of both worlds!
Old May 29, 2000 | 02:22 PM
Post
Alpha, the spec is on the washer portion of the nut for'99. When the nut was redesigned for'00 for the 14mm stud, the spec may not have been included. It should be in the owners manual though.
Old May 30, 2000 | 12:03 AM
alphadoggy's Avatar
Question
This is becoming curiouser and curiouser. I could have sworn that when the tire guy pulled one of my lug nuts to size it it had 100 lb./ft. stamped on it. So I just went out and pulled six different lug nuts from two different wheels, and none of them had a spec stamped on them?
I'd rather have a bottle in front of me than a frontal lobotomy.
'84 Alan Record Carbonio, Aerospoke wheels, Campy brakes.
'00 SVT Lightning, silver, G-tech Pro, JBA headers
gmvye@pacbell.net
