Stock L Dyno #s?
Old May 14, 2006 | 04:42 PM
khendrix2374's Avatar
Stock L Dyno #s?
What does a stock Lightning Dyno at roughly?
Old May 14, 2006 | 05:10 PM
HalfTime's Avatar
340 to 360 give or take, year, temps, dyno, setting on the dyno. Who cares really, a fyno is just for tunning, it's the track numbers that matters.
Old May 14, 2006 | 05:22 PM
Odin's Wrath's Avatar
I've seen posted here anywhere from 308 rwhp to 360 rwhp. I've seen trucks with 4# pulleys, full exhaust, chip, and CAI make just 380 rwhp or as much as 320 and more. I can't explain the difference in dyno numbers. Basically, there is no answer to your question. If you don't dyno your own truck stock, you'll never know what you personally have (had).
Old May 14, 2006 | 05:29 PM
I had a guess of about 340, but wasn't sure. Yes. The setting of a dyno run has ALOT to do with the #'s.
HalfLife: You are correct.. Track time matter most. But you can make 500HP and have an inferior suspension/trans setup and pull of some horrible times.
Thanks guys
Old May 14, 2006 | 06:34 PM
Falcon11's Avatar
The butt dyno is what matters most
Old May 15, 2006 | 01:51 PM
Unoid's Avatar
my 04 = 356/426 sae dynojet
Old May 15, 2006 | 01:55 PM
LightningTuner's Avatar
The 99-00s were in the 315-320 range. The 01-04s, are in the 345-350 range. Those are average numbers for stock trucks.
