installed my ftvb this morning
See Twizzler it was cake to install right
As for the ET's and now running slower, has NOTHING to do with the FTVB.
The only way you can really compare the runs are if the 60fts were the same, and the temps and conditions were identical. These trucks can run miles apart based on temp and track conditions.
What was the MPH on both runs ????
and WOO HOO on the FTVB
I ran at the track for the first time this year with a FTVB and i did notice a .05 faster time but.. the air was also about 3-4 degrees colder than i ran last summer, and i figure that was the dif from last years best times.
Going through the dyno book of all the lightnings he has done there are trucks with the same mods i have, but they do not show any real difference with a full exhaust. As Big svt says and as does my tuner fords exhaust works great up to the mid and high 400 hp range.
Originally Posted by Chikenears
It's a modified 2C accumulator valve body that is easily installed and dramatically shortens the shift duration, no more sloppy shifts. It's most people's first mod, or should be at least.
We keep them in stock and ship every day.
Get them here. http://www.chickenears.com/transmission.htm
Tim @ Chickenears
Tim @ Chickenears
I want to do it but I am not sure of my skillz and I can't find a place that wont rip me off around here to do it.31C
Originally Posted by 31Charlie
It was my first mod for sure, from you guys and everything. I still havent installed it yet, and I bought it back in 2004
31C
honestly its nothing harder than changing your oil all you do is drop the trans pan drain the fluid out little by little take out like 8 bolts put in the new part put the bolts back in tighten everything up and boom your done.
i know nothing about lightnings and i did it it took about an hour cause i was going slow but a small child could do this.. give it a shot
