DRLs?
Old May 18, 2000 | 02:40 PM
lightning_svt's Avatar
Lightbulb
They aren't Daytime Running Lights, they are Autolamps. I believe the Canadian trucks are the only ones with the DRL's.
BTW, from your description, the Autolamps are working normally. Basically it should activate the headlamps and parkinglamps when the sensor detects it's dark outside; or rather, activates the headlamps/foglamps when it does not sense enough ambient light after a certain time period. (The sensor is in the small grille on the top center of the dash.)
Hope this helps!
~rick
lightning_svt@hotmail.com
2000 Ford F-150 Lightning
Old May 18, 2000 | 07:08 PM
Red2000SVT's Avatar
Post
My DRL's, and they do put them on US vehicles for $190, stay on all the time if I have the little red toggle switch under the dash in the on posistion and the ignition is on. You may have that switch off and your lights on "auto" which is the setting all the way to the left so they only come on when dark. Check your lights outside it the daylight and if they are off, switch your toggle and see if they come on.
Did you pay for the DRL's? I think if you don't pay for it, they just don't tell you about the toggle switch.
Red 2000 SVT Lightning Leer Lo-Rider Bed Cover
PSP Filter (don't ask how I got it either )
Adopted 3/29/00
Silver 1998 Mustang GT Convertible 4 point Autopower roll bar and a bazillian other handling/engine mods.....
Old May 18, 2000 | 08:46 PM
Silver_2000's Avatar
Post
Checked to be sure.... I have no toggle switches under my dash. Alpha - If you give me details of the location I will check again - But I would have seen it when I wired the Valentine 1
Doug
Old May 19, 2000 | 12:13 AM
alphadoggy's Avatar
Question DRLs?
Are these things supposed to stay on all the time, or are they on some sort of photo-electric sensor, or something? Naturally I can't tell whether they are on or not while I'm driving around. When I first start up they normally go on (I keep the switch in the DRL position), but when I pull back into the garage they are usually off (?). When I turn the ignition off, they come back on for a few seconds, and go off again. The taillights come on to, although the manual says that the DRL switch does not activate the taillights. This strikes me as curious as I would thnk that you'd want your taillights on any time your headlights were on, especially in reduced visibility. Can anyone tell me how I determine whether mine are operating normally, or whether they are screwed up somehow?
I'd rather have a bottle in front of me than a frontal lobotomy.
'84 Alan Record Carbonio, Aerospoke wheels, Campy brakes.
'00 SVT Lightning, silver, G-tech Pro, JBA headers
gmvye@pacbell.net
