Question regarding first time to track
Old May 16, 2000 | 12:04 AM
Floyd91's Avatar
Question Question regarding first time to track
Will I need a helmet? Anything else? I have never legally dragged. Any info would be great.
Floyd91
Why do I do the things that I do? Because, The chicks dig it!
99.5 White lightning
#2349 Born on 6/14/99
Clear Corners
Clear Tail lights
APC Ultra White headlights
IPF Ultra White Driving lights
PSP Filter Kit
Superchip Flip Chip
BellTech 3/4 drop
Razo carbon Race Pedals
Old May 16, 2000 | 07:12 AM
99SVT's Avatar
Post
Depends on the track on whether or not you will need a helmet. Better bring one just in case. You will also need long pants and a closed toe shoe(no sandals).
Jerrod
Old May 16, 2000 | 07:57 AM
Silver_2000's Avatar
Post
Most places dont require a Helmet unless you run in the 13's.
Doug
Old May 16, 2000 | 04:32 PM
98_SVT_COBRA's Avatar
Post
All depends on the track, most will require a helmet for anything quicker than 14.0.
Old May 16, 2000 | 05:43 PM
4D THNDR's Avatar
Cool
If you tell the tech inspector you'll run in the 13's(I'm fairly certain you will ) he'll make ya get/borrow one(NHRA regs along w/pants,shoes). Call ahead, some rent helmets for a nominal fee. If they don't find out what helmet they require(Snell rating or DOT sticker). If ya can't get one just tell him ya don't know how fast then it's up to the timeslip guys to say something and I ran a bunch of times my first time there down to the 13.5's and no one said anything.
Red '00 Lightning,
Adopted 4/19/00,
PSP Filter,
Sound effects provided by Flowmaster,
Track time pending...
Old May 16, 2000 | 07:34 PM
noelvm's Avatar
Talking
Hit it the minute you see the third yellow come on. A reaction time of .5000 is perfect. Anything less will result in a redlite. Try to be consistant. Get as many practice runs as you can. Where we go on Friday you can go round and round and make a run every 3-4 minutes. Good practice.
noelvm
this is an 1/8 mile, you won't get as many runs at a 1/4 mile.
Old May 16, 2000 | 07:52 PM
BadDog's Avatar
Post
Drive around the water box, unless you're running slicks.
Turn your A/C off. You will be pulled from the line if you are leaking any fluids.
Actually it's your vehicle they worry about. If YOU leak fluids, no one cares unless it gets on the track.
Regards,
Gordon
99.5 Red Lightning
Only driven on Sundays (1/4 mile at a time)
Old May 16, 2000 | 09:43 PM
noelvm's Avatar
Talking
What bad dog says is very important. As these trucks tend to drop water for awhile even after the A/C is turned off, I turn mine off 10 miles from the track to ensure all the water is out by the time I get there.
noelvm
There are two sets of staging lites. He who lites the first set is expected to NOT light the second set until other person lites first set, then you can stage (lite) the second set which is only a few inches forward so creep with your foot on the brake ready to stop.
When you line up behind the cars that are at the tree ready to go. DO NOT DO your burnout until instructed to by guy in the middle. If you have to back up because you go through staging lites be sure and put gearshift back in drive. It may not make any difference but I alway run with the overdrive off. I also yell at truck during race and puff on a cigar. Sweat towell and water bottle are also a good idea and cooler with cold whatever. Alcohol is not recommended for internal consumption until racing is done because it will generally ruin your reaction time and consistancy.
Old May 16, 2000 | 10:01 PM
Floyd91's Avatar
Post
Not to mention the fact that Im underaged. Thanks for the info you all. What would happen if I run under 14 without a helmet?
Old May 16, 2000 | 10:26 PM
lightning2strikes's Avatar
Post
i went to kcir last week and they require a helment period so i would have one ready.. may be someone can check..
Old May 16, 2000 | 11:11 PM
4D THNDR's Avatar
Wink
As soon as you cross the traps without a helmet under 14 seconds you explode and disappear into the 15'th dimension. That or someone may tell you to get one before your next run. The most likely thing is that nothing will be said. You really should get/borrow/rent one though.
Red '00 Lightning,
Adopted 4/19/00,
PSP Filter,
[This message has been edited by 4D THNDR (edited 05-16-2000).]
Old May 16, 2000 | 11:48 PM
LightningDammitt's Avatar
Post
Exploding into the 15th dimension? I've been there!
Damn the colors sure are pretty! ONLY in a Lightning tho....
