Removing tow assembly
Old Apr 21, 2006 | 01:54 AM
sadf's Avatar
Just wanted to know how much it would raise the rear up if I removed it. I currently have an 01 w/ 2in shackles and removed leaf. I sell the suckers and they weigh alot so I figured if I removed it might raise the back up an inch.
Old Apr 21, 2006 | 02:58 AM
TheYak's Avatar
I don't think it would make any difference... it doesn't really weight that much.
Old Apr 21, 2006 | 06:29 AM
todd abbott's Avatar
I didn't measure but after removal I can't see a difference.
Old Apr 21, 2006 | 08:45 AM
wydopnthrtl's Avatar
I did measure the height differance. Removing the rear hitch raises the rear 3/8" to 1/2" as measured from the rear tire to the fender lip.
Removing the spare and spare winch raises it abotu the same amount.
Rich
Old Apr 21, 2006 | 07:50 PM
danjaimet's Avatar
Would you like to sell the hitch?? If so then I might be interested!
Old Apr 22, 2006 | 10:20 AM
sadf's Avatar
Sure... Shipping may be a little, though. P.M. me
Old Apr 22, 2006 | 02:15 PM
Tim Skelton's Avatar
Removing the spare and spare winch raises it about the same amount.
Rich
As an engineer, you should appreciate some math:
The leafs are 180 lbs/in. Assume that all of the weight is carried by the rear springs. Removing a 45 lb hitch should raise it .25". Removing the 68 lb. spare and winch should raise it .38". So the total lift calculates to .63", which is about 5/8", just below the lower limit of 3/4" predicted by your measurements.
Old Apr 23, 2006 | 01:01 PM
MAT2CH's Avatar
Not to sound like I'm trying to give you crap, but are you really an engineer?
Old Apr 23, 2006 | 01:51 PM
Sharpshooter's Avatar
No he is a lawyer, and Rich (wydopnthrtl) is the Engineer.
Old Apr 24, 2006 | 11:53 AM
RhinoSlug's Avatar
So, together they can construct an awesome pile of BS.
Old Apr 24, 2006 | 08:57 PM
pitstain's Avatar
BUT Tim Skelton stayed in a Holiday Inn Express last night !!!!!
