What size belt?!?!?
Old Apr 20, 2006 | 11:55 PM
Falcon11's Avatar
What size belt?!?!?
4LB lower, stock upper, and Metco idler pulleys.
Stock is 66", so 68" or 68.5"???
Old Apr 20, 2006 | 11:59 PM
LightninSVT's Avatar
I used a 68" belt, no problems. May have to break the tab off...
Jon
Old Apr 21, 2006 | 12:04 AM
Falcon11's Avatar
Jon
Break the tab off?
Old Apr 21, 2006 | 12:25 AM
There is a little tab on the tensioner that acts as a "stop" when loosening the bar. It is cast, so if you take a screwdriver or chisel and give it a whack it breaks right off to allow the tensioner to push down further. This helps with getting belts on with larger pulleys. I don't have a picture but you'll see when you get into it.
Just put a 1/2" wrench in the front of the tensioner and turn clockwise until it won't move anymore. You'll then see the tab that is stopping it from moving - break that off.
I'm sure if you search you can pull up some more information on the tensioner tab.
Old Apr 21, 2006 | 07:39 PM
Falcon11's Avatar
thanks guys.. Why don't I just go with a 68.5" belt. Then I won't have to break the tab off, correct?
Old Apr 23, 2006 | 07:56 PM
Falcon11's Avatar
anyone?
Anyone have my setup?
Need to order belt asap...
